Rear Defroster Hook Up - JeepForum.com
post #1 of 8 Old 10-20-2002, 08:34 AM Thread Starter
SnowMan
I just put the hard top on my jeep for the first time and was wondering if anyone knows the wiring to hook up the rear defroster on the rear window. The haynes and the chilton don't say anything that I can find about the wiring. If anyone knows how to do this please let me know.
Is that you John Wayne, is this me!
SnowMan is offline
post #2 of 8 Old 10-20-2002, 02:48 PM
Meister_jeep
look at the rear fender inside the jeep (drivers side) there is a wire that goes through the fender and there is a splice that does not go through with the rest. It has a connector at the end that has like 4-5 outputs it connects in the connecter that is fixed to the hardtop
them you have to hook up the little terminals on each side of the rear window. There are 4 (2 on each side) they are on the liftgate cylinders that hold the liftgate up
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
post #3 of 8 Old 10-20-2002, 06:21 PM
kennyb
kennyb's Avatar
defrost
does the hard top even have a defrost on it becasue I know the mine doesn't even have the defrost and I think as far as I know only the TJ's have the defrost. but I am not sure you have to check on it.
kennyb is offline
post #4 of 8 Old 10-20-2002, 06:42 PM
moabster
moabster's Avatar
2011 WK
Our 93 YJ has a defroster on the hard top. There is also a hose for the washer fluid and the wiring for the rear windshield wiper in the same bundle of wires.
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #5 of 8 Old 10-20-2002, 06:51 PM
thecarman
My 94 YJ has it, but I have no idea how to hook it up... or how it even connects in back in the back.
1994 Jeep Wrangler 2.5L (White)
thecarman is offline
post #6 of 8 Old 10-20-2002, 07:36 PM
Meister_jeep
my 1988 has it too and it is easy as looking to hook it up
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
post #7 of 8 Old 10-21-2002, 05:12 AM Thread Starter
SnowMan
Meister_jeep, in the back fender I have a small hole that wires are shrink wrapped and then go through a rubber plug. Does that connector that you have go down in there? I originally had the soft top on it factory but I don't think that would make a difference.
SnowMan is offline
post #8 of 8 Old 10-21-2002, 08:22 AM
Meister_jeep
here is a picture of the connecter that I took when I restored my jeep you see the plug and the connecter that sticks out just before the plug IT DOES NOT GO THROUGH THE FENDER. check the picture here
http://drums-nation.hypermart.net/ebay/DSCF0033.JPG
hope this helps. You might not have the connecter if you did not have a hardtop from the factory but I wouldn't see why they would bother to make different wiring harnesses
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
rear defroster D_Dude2000 YJ Wrangler Technical Forum 2 01-31-2012 12:25 PM
new hardtop, how do I hook up rear wiper and defroster?? nooch13 TJ Wrangler Technical Forum 16 07-27-2011 10:43 PM
Rear Defroster Hel*! joemac421 TJ Wrangler Technical Forum 1 11-19-2009 07:54 PM
rear defroster or not boaty1 YJ Wrangler Technical Forum 4 09-10-2008 07:03 PM
Rear Defroster Jarvo2 TJ Wrangler Technical Forum 8 01-16-2008 07:49 PM
