Rear defroster - JeepForum.com
post #1 of 10 Old 11-02-2009, 11:14 PM Thread Starter
JimmySystem
Rear defroster
So the rear window on my hard top has a rear defroster on it with a plug coming out, but the Jeep isn't wired for one. Has anyone else wired their Jeep for a defroster? My Haynes manual isn't much help, so is there a write up or some sort of instructions out there?
JimmySystem is offline
post #2 of 10 Old 11-02-2009, 11:36 PM
DiabloYJ
I was wondering this as well. Especially since I just located what I believe is the wiring harness for the hardtop on another Jeep at the junkyard. I just haven't had a chance to go back and grab it yet to give it a shot on mine.
"When Life starts to pass you by..............Downshift"
Then again that used to be my motto until I got the Jeep, now that doesn't even work half of the time.
GD Thread HIJACKERS Member #1
ΜΟΛΩΝ ΛΑΒΕ
-Justin
Originally Posted by 2006Sport View Post
Sometimes I wish I had leaf springs.
DiabloYJ is offline
post #3 of 10 Old 11-03-2009, 02:50 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Information already posted can be found by using the Search this forum function at the top of the list of threads.
Here you go:
http://www.jeepforum.com/forum/f12/h...arness-866334/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 10 Old 11-04-2009, 09:05 AM Thread Starter
JimmySystem
Thanks for the info, winter might not be so bad now.
post #5 of 10 Old 11-04-2009, 11:56 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
I just had a 'brain fart'. The information I is offered is for later model YJ's Probably '91 to '95, most definiately '93 to '95 YJ's.
You have an '89 YJ and I am almost positive that it is wired up in a different manner. There might be a space for the rear defroster TIMER relay in the Power Distribution Center (PDC). I believe that there is a seperate wiring harness for the rear defroster also that does not have any relay in it like the newer YJ's have.
post #6 of 10 Old 11-04-2009, 12:15 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Check this out: Note post #11 by JBOLTY. I think he posted the information you need.
http://www.jeepforum.com/forum/f12/9...p-rear-629399/
post #7 of 10 Old 11-04-2009, 12:29 PM
dodger889
Before you get all excited I would check it and make sure that it might even work after you apply power to it. Get the multimeter out and check that you have a good circuit on the window.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #8 of 10 Old 11-04-2009, 06:54 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
The older Yj's had a diferent set up than what we have showed you. I think that JBOLTY is offering basically the same information I have done. The earlier Yj's had a different set up for sure. There was two fuses under the dash on the fuse panel that protected the circuitry and there was also a TIMER realy involved. I think it might have been located under the dash but that is just speculation on my part. A FSM for that vehicle would map out all of this for you. One thing I am fairly sure of is that the rear hardtop wiper/defroster wiring was different in the early YJ's than the one in the newer YJ's.
Here is a link to one for sale on EBAY (which is way expensive!) Jeep Wrangler YJ Hard Top Wiring Harness 1989:eBay Motors (item 230358055385 end time Nov-13-09 09:59:38 PST)
EDIT: This is what the tub harness looks like for the newer YJ's. Note the red timer relay and it's red socket are paret of the tub harness.
post #9 of 10 Old 11-04-2009, 07:15 PM
UnFocused
I've got an '89 and Laybackman provided much info to me to get it wired. There should be a red plug under the dash to the right of the steering column near the heater controls connected to nothing; that will connect to the defroster switch and was part of the standard dash wiring harness. The wiring from it routes to a 3 wire plug above and to the left of the fuse box, also connected to nothing. Might be wrapped in foam and buried someplace up in there.
Check to see if there is a red relay socket near and above the emergency brake pedal; if it's there, that's for the 10 minute defroster timer relay and your jeep came from the factory with that option installed. If the red socket is missing (which is probably the case), you'll have to buy the entire harness, complete with socket and relay, over Ebay or from a junk yard as others said; I got mine from a yard for $50.
Regardless of the results, here's the diagram Laybackman provided:
http://home.comcast.net/~laybackman/95YJ_reardef.pdf
If you're unsure of the wire colors, pull the relay and look very closely on the bottom next to the pins. It's hard to see, you'll need to have the light just right, but they are numbered 1 through 5. Those correspond to the small numbers on the above diagram; then you can trace the harness to the relay.
Thanks again Lbm!!
UnFocused is offline
post #10 of 10 Old 11-06-2009, 06:35 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Thanks again Lbm!!
You are quite welcomed!
That rear defroster is nice isn't it!?
rear defroster D_Dude2000 YJ Wrangler Technical Forum 2 01-31-2012 12:25 PM
Rear Defroster Jarvo2 TJ Wrangler Technical Forum 10 03-16-2011 05:16 PM
Rear Defroster Hel*! joemac421 TJ Wrangler Technical Forum 1 11-19-2009 07:54 PM
rear defroster or not boaty1 YJ Wrangler Technical Forum 4 09-10-2008 07:03 PM
Rear Defroster Jarvo2 TJ Wrangler Technical Forum 8 01-16-2008 07:49 PM
