Rear crossmember repair / replacement - JeepForum.com
post #1 of 11 Old 03-11-2009, 07:22 PM Thread Starter
trucknut
Hey guys,
I'm sure someone in the salt belt has encountered this problem before with a YJ.
The crossmember by the rear wheels that supports the front of the gas tank and tank skidplate assembly has completely rotted off on both sides causing the front of the gas tank to drop coming to a rest on the rear axle! Currently it is being held up by a ratchet strap... My local dealer tells me the crossmember is no longer available through Jeep... anyone know where i can purchase this part? I would prefer to fix it somewhat properly but if need be i will fab something to hold it, god i just love rust
1994 Jeep YJ 2.5
My Save the YJ from the junkyard project...
2001 Toyota Tundra TRD
trucknut is offline
post #2 of 11 Old 03-11-2009, 08:30 PM
bob082484
Mines startin to go too. I was thinkin of long bolts through the floor of the body as a temporary fix. A more permanent fix would be to find a piece of metal as wide as the inside of the frame rails and either find a way to bolt it to the sides or weld it.
bob082484 is offline
post #3 of 11 Old 03-11-2009, 08:31 PM
Ben_88Jeep
2010 JK Wrangler
I do know that the guys at Gemini-Sales.com in B.C. have used replacement crossmembers for about 50 bux. Less snow n' salt over here on the west coast, so maybe that'll do the trick for ya....
Ben_88Jeep is offline
post #4 of 11 Old 03-11-2009, 08:35 PM
Mark05059
not sure if these are what your looking for or not
http://www.quadratec.com/products/22508_02_07.htm
Mark05059 is offline
post #5 of 11 Old 03-11-2009, 08:55 PM Thread Starter
trucknut
I noticed mine going about a month ago really bad, i removed the hard top, unbolted all body mounts, wrapped some chain falls around the rear roll bars and lifted the body off the back, i welded a patch over a large tear in the crossmember on the passengers side... the other day the drivers side let go and ripped the patch clean off on the passengers side to deystroying what was left of the crossmember, the "through the floor" fix is something i am considering for now too, i was going to put a piece of diamond plate aluminum over the rear section of the floor to give it added strength...
Thx i will check them out, shipping would likely be very high since i am on the east coast (Saint John, New Brunswick)
Nope thats not it, between the actual frame rails by the rear wheels just slightly behind the rear axle, the front of the gas tank and gas tank skid plate actually bolt to the crossmember, i will post some pics soon, dark and raining here at the moment...
1994 Jeep YJ 2.5
trucknut is offline
post #6 of 11 Old 03-11-2009, 09:12 PM
texas_yj
you need a welder friend, just looked at mine (love the texas rust free zone ) and it would be easy to fab up a replacement, even if you have to add some mounting pads to the frame rails because of rust there too. just need a mig, maybe a muffler shop could help ya out, bring them the needed metal, and they weld it in for ya???
Sold) 94 YJ, 4.0L 5 sp manual, Hard top, 33/12.50s, 4.10 ring&pinions, Polished D30 w/Aussie front, 8.8 rear w/ LS, 2.5" RC, 2" BL, 5/8" booms, TJ flares, SYE, custom F/R bumpers and rock sliders, 8k winch, dual optimas, HO alt.
2) (Sold) 99 TJ, mustang 5.0 GT 40, AX15/231J, trektop, 37x12.50r17 cooper STT, superlift 6" long arm, D30/44 w/ ARBs & yukons, customized warn bumpers, custom sliders, 12K winch w/ synthetic rope, custom paint
3) 2007 JKU being built now
texas_yj is offline
post #7 of 11 Old 03-11-2009, 09:30 PM
93jeepyj
mines almost gone too, something pre fabbed would be nice but it woudnt be too hard to make either
93jeepyj is offline
post #8 of 11 Old 03-13-2009, 08:06 PM
bob082484
Just started work on repairing mine today. Picked up some bar stock and a couple L brackets and came up with this. I plan on bolting it in between the frame rails. http://i610.photobucket.com/albums/t...rossmember.jpg
post #9 of 11 Old 03-13-2009, 09:48 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
here ya go
http://www.4wd.com/productdetails.aspx?partID=7878
still, for $100 i would build my own and make it a real structural member instead of just a little spreader bar for your frame rails.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #10 of 11 Old 03-13-2009, 10:09 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Originally Posted by sentinal02 View Post
here ya go
that is the one for the very back isnt it?
he needs the one that the FRONT of the gas tank mounts to i believe.
i'm about to make one for a mate of mine, out of either flat stock or angle iron, drilled for the tank and body mounts. shouldnt cost more than $20 in steel, and be @200% stronger to boot.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #11 of 11 Old 03-13-2009, 10:21 PM
sentinal02
sentinal02's Avatar
martin
whoops, missed that detail
Rear crossmember replacement Que89YJ YJ Wrangler Technical Forum 2 09-02-2009 10:18 AM
Front Crossmember Replacement Nuge TJ Wrangler Technical Forum 17 05-05-2009 10:38 PM
Trans crossmember repair or ideas AC_Spiderman YJ Wrangler Technical Forum 6 04-01-2009 07:37 PM
'90 Crossmember replacement? grangalan YJ Wrangler Technical Forum 4 11-13-2008 02:58 PM
Rear Crossmember Calvin4186 YJ Wrangler Technical Forum 8 05-15-2008 01:04 PM
