Rear crossmember - Page 2 - JeepForum.com
post #16 of 19 Old 08-12-2011, 07:54 AM
pasinbuy
Poke made a nice rear cross member. http://www.jeepforum.com/forum/f12/jeep-envy-1210561/
I would recommend using 1/4" or plus steel. Especially if you want to add a recovery point or a hitch receiver.
pasinbuy is offline
post #17 of 19 Old 08-12-2011, 10:31 AM
Que89YJ
Someone pointed out to me the rear cross member can be replaced by using the stock front bumper as a replacement more than strong enough and readily available.
Que89YJ is offline
post #18 of 19 Old 08-12-2011, 11:16 AM
92 Green YJ
92 Green YJ's Avatar
I agree with making a new, beefier crossmember and calling it a day. the factory one is tinfoil. You can use angle iron or plate steel. Personally I ended up making a new rear bumper and just welded it straight to the rear frame horns. My rear bumper IS my rear crossmember now.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #19 of 19 Old 08-12-2011, 12:47 PM
hrt4me
so you didn't weld it to the existing rear crossmember, but removed that first, correct?
any pics?
hrt4me is offline
CJ-7 vs Wrangler YJ rear crossmember Chris Aunchman YJ Wrangler Technical Forum 1 01-19-2010 02:34 PM
have you reinforced your rear crossmember? Poke YJ Wrangler Technical Forum 5 03-11-2009 02:06 PM
Rear Crossmember Calvin4186 YJ Wrangler Technical Forum 8 05-15-2008 12:04 PM
Broken rear crossmember mjeselskis YJ Wrangler Technical Forum 3 12-12-2005 06:48 AM
Rear Crossmember replaceable? Muddeprived TJ Wrangler Technical Forum 3 01-26-2005 02:29 PM
