rear corner repair - JeepForum.com
post #1 of 2 Old 08-08-2006, 12:35 PM Thread Starter
whyjay
rear corner repair
my 89 yj has a very good body ,just before I got it someone dented the rear drivers side corner. Looks like it came down on a rock. It didn't bother me much but I've noticed it's starting to rust. How hard is it to replace that pannel? Or any other suggestions would be appriciated
whyjay is offline
post #2 of 2 Old 08-08-2006, 04:44 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
sand it, prime it, spray paint it
then install corner guards (whatever you call those things)
-Erik <--- is fixing dented rear corners the same way when i can afford to do LED tails
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
Rear corner and valence Que89YJ YJ Wrangler Technical Forum 1 08-31-2009 10:49 AM
YJ rear corner panel KoonassKen YJ Wrangler Technical Forum 17 08-30-2009 06:42 PM
Rear Corner Guards Help bail315 TJ Wrangler Technical Forum 1 03-21-2008 04:21 PM
Roll bar - rear corner stantjeeper85 TJ Wrangler Technical Forum 4 07-04-2006 03:16 PM
Rear corner protection dirtgrip TJ Wrangler Technical Forum 4 06-02-2004 01:14 PM
