Rear Bump Stops... how did you extend yours? - JeepForum.com
post #1 of 6 Old 06-01-2010, 10:32 PM Thread Starter
Burns95
My Jeep is back together after the 8.8 install, regear and now 35's. I've trimmed my rear fenders as much as possible, and am still rubbing on full flex. It's time to measure and drop my stops. I am thinking about welding a piece of 2x2" tubing to my frame, and bolting the factory stops to the 2x2. This will give me 2 inches of extra stop. Any other thoughts? What's worked and what hasn't?
I have a big three day wheeling trip coming up on Friday. Please send me your ideas with pics if possible.
PS... Front is fine since I flat fendered the front. Just the back has issues.
Burns95 is offline
post #2 of 6 Old 06-02-2010, 05:33 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
You could leave the pad alone and raise the axle bump point. Many SUA lift kits come with towers you clamp under the u-bolts. I have SOA and welded up a 'landing pad' on top of the u-bolt plate. In my case I had to do something, since the rubber would have been hitting the threaded ends of the u-bolts.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline
post #3 of 6 Old 06-02-2010, 09:00 PM
bpr
I did an 8.8 but did my own u-bolt flip during the process. I extended my bumpstops by cutting a piece of driveshaft tubing I had laying around. Cut it to length, welded a cap on it, then welded other end to top center portion of my ubolt plate. A little black paint and done.
bpr is offline
post #4 of 6 Old 06-03-2010, 07:25 AM
jeepinmichguy_
i dont have any on the yj
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #5 of 6 Old 06-03-2010, 07:33 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
That's not the best approach for two reasons, either 1) the tub sheet metal becomes the compression limit, resulting in bent stuff or cut tires, or 2) The shock becomes the compression limit, resulting in broken shocks or mounts.
post #6 of 6 Old 06-03-2010, 07:38 AM Thread Starter
Burns95
Thanks for all of the responses. I welded a piece of square tubing to the frame and bolted my stop to the tubing. Havent flexed it yet, but I will try it tonight.
Burns95 is offline
Rear Bump Stops on TJ... ???? surfTJsnow TJ Wrangler Technical Forum 14 05-30-2010 08:49 PM
TJ rear bump stops help Devilstoy TJ Wrangler Technical Forum 18 12-06-2009 10:24 PM
Extend Bump Stops? MattSink TJ Wrangler Technical Forum 3 05-15-2009 10:03 AM
to extend bump stops or not kman8 TJ Wrangler Technical Forum 3 08-26-2008 04:42 PM
Why Only Rē Rear Bump Stops On A BB? M2LJ TJ Wrangler Technical Forum 7 11-29-2007 08:18 AM
