rear brakes, wtf is this part??? - JeepForum.com
post #1 of 13 Old 06-24-2011, 10:04 PM Thread Starter
Ripper3494
what is the little brass piece? its off of the rear brakes, this one is off of a wagoneer but its the same part, none of the auto places around here have it, not even a dealership
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 13 Old 06-24-2011, 10:06 PM
theducksguts
It's a combo block. It takes the soft rubber hose coming off the hard steel brake lines and splits the flow of brake fluid to both drums.
I got mine at Oreilys. They are a pretty generic part.
Check out my
theducksguts is offline
post #3 of 13 Old 06-24-2011, 10:33 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Buy a new rubber brake hose at the auto parts store, it comes with one of those already installed.
CJ7-Tim is offline
post #4 of 13 Old 06-25-2011, 12:01 AM Thread Starter
Ripper3494
i tried to buy the brake hose as well but they didnt have any of those either lol
build thread:
RC vs BDS
post #5 of 13 Old 06-25-2011, 07:34 AM
CJ7-Tim
CJ7-Tim's Avatar
Even if you live in Buttstink IL, they can order your parts and have them in a day or two.
CJ7-Tim is offline
post #6 of 13 Old 06-25-2011, 09:02 AM
theducksguts
Then you need to go to a different store. This is a common, most of the time universal part for light trucks.
Check out my
post #7 of 13 Old 06-25-2011, 10:27 AM Thread Starter
Ripper3494
i asked them to order what i think was correct but they said they cant order it unless im positive its correct
build thread:
RC vs BDS
post #8 of 13 Old 06-25-2011, 10:48 AM
CJ7-Tim
CJ7-Tim's Avatar
If the parts store can't tell you what parts are correct for your Jeep, they are mouth breathing Idiots and you should find a better place to spend your money.
Any of these will fit a stock YJ axle -
Jeep 52004152
AC DELCO #18J798
WAGNER # BH123814
CENTRIC # 15067322
RAYBESTOS # BH38845
MIDAS # BH2221
NAPA # 38845
CJ7-Tim is offline
post #9 of 13 Old 06-25-2011, 11:19 AM
jbolty
jbolty's Avatar
Not sure what help you're looking for. Are you doing an axle swap, replacing a stock brake line or looking for extensions?
This hose and fitting could not be any more common. Just about every vehicle has something like it.
jbolty is offline
post #10 of 13 Old 06-26-2011, 11:29 AM Thread Starter
Ripper3494
I'm actually doing an axle swap with the rear axle of a 91 wagoneer, I'm gonna try a jeep specialty shop about a half hour away today, since none of the regular stores here even carry the rubber brake hose
build thread:
RC vs BDS
post #11 of 13 Old 06-26-2011, 12:27 PM
CJ7-Tim
CJ7-Tim's Avatar
Is your Google broken ?
1991 Wagoneer brake hose :
CENTRIC Part # 15067306
WAGNER Part # BH88983
RAYBESTOS Part # BH36802
CJ7-Tim is offline
post #12 of 13 Old 06-26-2011, 01:58 PM Thread Starter
Ripper3494
thank you and no, the reason i was asking was because i didnt even know what the part was so i had nothing to really look up
build thread:
RC vs BDS
post #13 of 13 Old 07-02-2011, 03:41 PM
grandpa63
any body got a picture of the rear brakes, a friend took his apart and wants me to help him put them back on, i could probley do it but a picture woul help
grandpa63 is offline
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 07:34 AM
time for new brakes have disc brakes front and rear rutacon05 TJ Wrangler Technical Forum 19 02-08-2011 06:23 PM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 06:25 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
