rear brakes/emergency cable - JeepForum.com
post #1 of 10 Old 04-14-2010, 11:33 PM Thread Starter
newyj
my emergency brake seems to be hit or miss sometimes it works and sometimes it doesn't. any ideas?
wave back dammit, don't leave me hangin!
yes, I wave at night too
newyj is offline
post #2 of 10 Old 04-14-2010, 11:53 PM
provinT13
When does it and doesn't it work?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 10 Old 04-15-2010, 02:56 AM Thread Starter
newyj
random doesn't seem to be any particular time or slope, forward or backing
newyj is offline
post #4 of 10 Old 04-15-2010, 04:01 AM
timatoe
timatoe's Avatar
Doesn't work as in it won't hold the Jeep in place or the pedal doesn't stay down? If you're having pedal issues go here... My Jeep: Official Jeep Owners website - Warranty, Vehicle Specs, Service Contracts, Financing, Dealers .... and under recalls put in the last 8 digits of your VIN. There was a recall on the e-brake assembly yours may not have been done.
timatoe is offline
post #5 of 10 Old 04-15-2010, 05:56 AM
bigsquat
if its not popping off like tim suggested, then if your shoes are ok ,just ejust the rear brakes. if that doesnt do it there is an ejuster on the ebrake cable under the jeep where the 2 back cables meet the front ebrake cable. mine wont adjust there because its frozen. and the dam foot pedal pops off at any given time. i have to get the recall done. tim go to bed! i would pull the rear drums and have a look if they havnt been off in a while. there could be axle or brake fluid on the shoes also
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #6 of 10 Old 04-15-2010, 09:32 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I just got done fixing this issue on my Jeep. Mine was caused by broken tabs on the rear e-brake cables that secure the cable to the drum support plate. Have a look at the cables on each end and make sure they are good and tight.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #7 of 10 Old 04-15-2010, 09:32 AM
timatoe
timatoe's Avatar
Originally Posted by bigsquat View Post
tim go to bed!
I'm going now, just got home from work and taking kids to school.
timatoe is offline
post #8 of 10 Old 04-15-2010, 01:22 PM
bigsquat
wow i really spell bad late at night!
bigsquat is offline
post #9 of 10 Old 04-15-2010, 02:15 PM
provinT13
When it does slip is it out of gear, and when it doesn't slip is it in gear?
post #10 of 10 Old 04-18-2010, 09:06 PM Thread Starter
newyj
when it doesn't hold I keep it in gear, I can feel it not tightening when I push in the peddle
newyj is offline
How To Tighten Emergency Brake Cable??? rastaangel TJ Wrangler Technical Forum 10 09-19-2009 03:07 PM
removing emergency brake cable MillerTimeTJ TJ Wrangler Technical Forum 2 05-25-2009 03:29 PM
Emergency Brake Cable - Currie Control Arms ramrat TJ Wrangler Technical Forum 6 05-11-2009 07:34 PM
emergency brake cable Jeepin' Rock Cl TJ Wrangler Technical Forum 0 12-05-2007 07:10 AM
Extended Emergency Brake Cable ?? Mjjeeps YJ Wrangler Technical Forum 2 08-13-2006 01:50 AM
