Rear Brake Line Extension Question - JeepForum.com
post #1 of 3 Old 04-05-2010, 03:58 AM Thread Starter
mrciscoe
I put on my brake line extension kit to accmodate my new EMUs and have a quesiton about the rear one.
The original one was more form fitting to the axle and thicker by 1/8" or more. I'm not so concerned over the form fitting but the thickness of the block. The axle 'breather' is quite long and now extends father into the axle housing. Is this a problem??
Thanks!
mrciscoe is offline
post #2 of 3 Old 04-06-2010, 04:04 AM Thread Starter
mrciscoe
-Bump-
Has anyone changed the rear flexible brake line? I don't want to damage the axle...
mrciscoe is offline
post #3 of 3 Old 04-06-2010, 04:58 AM
budello
1987 YJ Wrangler
I've just do it using goodrigde extended lines. i add some spacers between axle and blocks, it works .
budello is offline
Need help--'03 TJ rear brake line extension zsparks TJ Wrangler Technical Forum 4 03-27-2010 11:46 PM
brake line extension question mmarmouz TJ Wrangler Technical Forum 10 08-19-2009 03:30 PM
Question about installing front brake line extension with 4"RE lift wessy YJ Wrangler Technical Forum 8 07-17-2008 02:06 AM
Rubi Express Rear Brake line extension EJames1226 YJ Wrangler Technical Forum 4 01-24-2007 12:29 PM
brake line extension KU krawler TJ Wrangler Technical Forum 2 07-20-2003 11:52 PM
