Rear Axle Wrapping - JeepForum.com
post #1 of 8 Old 05-03-2001, 12:01 PM Thread Starter
Loomis4wheeler
Rear Axle Wrapping
First, I want to thank everyone who replyed to my last email question. This next question is about axle wraping on a spring over setup. Whats my risk?
Loomis4wheeler is offline
post #2 of 8 Old 05-03-2001, 07:14 PM
Tonka
2015 JK Wrangler
Axle wrap is much more likely to happen in a sprung over rig.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 8 Old 05-03-2001, 07:16 PM
rayray
rayray's Avatar
Risk? I dunno if there is really risk. More like a nucance. I take that back. You do run the risk of drive line binding. Hense, ujoints and drive shaft are at risk. That's probably the main thing.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #4 of 8 Old 05-03-2001, 07:21 PM
jpwranglr9
I did a spring over on my 95 YJ. Axle wrap is a very serious problem when doing a SOA. I tried the stock springs that lasted one day. running with 33's using stock springs don't work. what i did was use BDS 2" lift springs in the rear and 4" pro comp in the front. i also put a shackle in the rear to make the lift work. the front springs were sagged to about 3" of lift but were great to hold all the weight and still have excelent travel. the BDS arn't holding up so im thing of maby going to 3.5" bds with no shackle. that ever you do, a lift spring of some kind almost a must. that does mean a lot more lift, so drive line mods and stearing mods are a must as well. If u dont have a hard top, i did a lift to a frends jeep with the full 2" bds lift and SOA and that works great, even with 35" BFG's. hope this gives you some ideas into what it takes to to a SOA.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
post #5 of 8 Old 05-03-2001, 07:30 PM
Tonka
2015 JK Wrangler
Ah a fellow michigander. I thought michigan jeepers were an endangered species
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #6 of 8 Old 05-03-2001, 08:53 PM
jpwranglr9
Still here, live and strong!
post #7 of 8 Old 05-04-2001, 12:11 AM
Razskidoo
Here as well!!
92 Wangler ,I-6 ,3"lift, 32x12.5
Razskidoo is offline
post #8 of 8 Old 05-04-2001, 12:58 AM
osburn
osburn's Avatar
SOA, you will have wrap. With 33s, wrap really isn't so bad you can't manage the trail. Vertical steps will be the problem, but otherwise you'll probably be ok. Hit the steps at an angle is one way to deal with it. Traction bars of course are the ultimate solution, but still with 33s it ain't too awfully horrible.
As far as the springs go, no doubt stockers all by themselves don't last worth a damn. But I ran stock YJ springs with the 2" Rancho Add-a-leaf on all four corners with excellent results for about 3 years. Those same springs are now on my son's SOA YJ and he got my stock axles and tcase. Which would make you assume that everything should work out the same. Wrong. His Jeep is much lighter than mine (he hasn't the tools and spares I carry yet) and we actually had to cut off and reweld the perches for a new angle. So he gets much more lift than I did out of them.
Matt Osburn
Score 1032
osburn is offline
camo wrapping deltaredneck TJ Wrangler Technical Forum 11 07-31-2009 11:53 AM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Alternative to painting interior, Vinyl wrapping (pics) TXjeepTJ TJ Wrangler Technical Forum 9 05-18-2009 04:45 PM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
Heat Wrapping Headers Atwater10 YJ Wrangler Technical Forum 5 05-11-2004 06:03 AM
