Rear Axle Repair - JeepForum.com
post #1 of 9 Old 02-08-2010, 10:47 PM Thread Starter
pasinbuy
Rear Axle Repair
Yesterday I made a thread and in the heading I typed " Rear Driveshaft Repair" . The thread heading should of read Rear Axle Repair. I did not know how to edit thread heading?
Here is the thread; http://www.jeepforum.com/forum/f12/r...repair-967046/
Anyway my question is:
The driveshaft bearing is definatly bad. I will replace the bearing.
A new axle is $97.00. The bearing surface on the old axle is not to bad but it is a little scored. Should I resurface the old axle?
Am I better off to just get the new axle for $97.00 and the matching bearing or ............. or to reface the old axle ?
What do you think?
Another thought was to replace the old axle for a new one the and use the old one for a spare in a emergency?
Another question: If one axle goes will the other be shortly behind? Should I replace both rear alxes while I am in there?
The YJ has about 133,000 miles.
pasinbuy is offline
post #2 of 9 Old 02-08-2010, 11:24 PM
wish_bw
If it was me I would replace both bearings why you were at. I really don't know about refacing them, I put a after market set in mine stronger that way.
wish_bw is offline
post #3 of 9 Old 02-09-2010, 07:05 AM
jsawduste
2006 YJ Wrangler
C`mon, if the bearing surface is scored then you know the answer.
What is a driveshaft bearing ? Transfercase output bearing or pinion bearing.
jsawduste is offline
post #4 of 9 Old 02-09-2010, 07:17 AM
dodger889
The axle could be repaired but it would be cheaper to replace since the parts are out there.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #5 of 9 Old 02-09-2010, 08:01 AM
jbolty
jbolty's Avatar
The less spent on fixing a D35 the better. Replace the bearing and seal and move on. You can fill a dump truck with D35 axle shafts at any junkyard so don't pay any more than you have to.
jbolty is offline
post #6 of 9 Old 02-09-2010, 08:40 AM Thread Starter
pasinbuy
My question was reface the shaft or buy a new shaft.
The driveshaft part was a mistake that I could not edit.
pasinbuy is offline
post #7 of 9 Old 02-09-2010, 02:02 PM
Opihi59
from here it gets rough
Opihi59's Avatar
I believe I understand what you are asking--cheapest option is to just go get a junkyard shaft. This should cost you way less than what you are anticipating otherwise. While there are not that many Wranglers in junkyards, there are tons of D35 equipped Cherokees out there. Go pull one, and it's done.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #8 of 9 Old 02-09-2010, 04:27 PM Thread Starter
pasinbuy
Opihi,
Thank you. What should I pay at a yard for a axle.
pasinbuy is offline
post #9 of 9 Old 02-09-2010, 04:41 PM
jbolty
jbolty's Avatar
Should be no more than about $25. If you want a spare set get both sides, as they are not the same length.
jbolty is offline
Need Info on Dana 35c Axle bearing repair Corys2000tj TJ Wrangler Technical Forum 25 12-25-2014 04:26 PM
Broke Rear Axle In Snow - Repair Price/Diagnosis Sound Right? lenhart1 TJ Wrangler Technical Forum 17 02-10-2010 02:12 PM
Sheared my axle in half... need help with repair and how to avoid doing it again rissacher TJ Wrangler Technical Forum 30 03-05-2009 10:27 PM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 03:23 PM
Dana 30 - Axle Shaft Trail Repair Question Overdrive TJ Wrangler Technical Forum 7 03-20-2007 02:56 PM
