Rear axle questions about driveshafts - JeepForum.com
post #1 of 12 Old 10-23-2013, 07:31 AM Thread Starter
Benzfrd
I have a 94 yj. The axles are stock with custom driveshaft in rear only. I only run 33 tires and have no reason to get larger any time soon
I have a few questions
1. I think I broke the front axle half shaft. I was able to buy a tj full shaft for $25 and was thinking of just fixing it. But is it worth it with all the effort. Or should I just upgrade the front axle ?
2. Would I be able to use the stock driveshaft in the front with a dana 44 front ?
3. Would the measurement change for the rear driveshaft if I were to put in a 8.8 ?
4. Could I use the custom shaft I have now if I did put in the 8.8?
Benzfrd is offline
post #2 of 12 Old 10-23-2013, 07:41 AM
1998zj
I didn't have to change my rear driveshaft when I changed to the 8.8. I put a Cherokee shaft in the front, it is pretty easy to do. Just put a seal in the pumpkin and put the new shaft in.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #3 of 12 Old 10-23-2013, 07:48 AM Thread Starter
Benzfrd
What is the lift you have on your rig
Benzfrd is offline
post #4 of 12 Old 10-23-2013, 07:52 AM Thread Starter
Benzfrd
Also is the dana 30 in the front with a new axle shaft gonna be strong enough to run the 33s or would it be best to upgrade
Benzfrd is offline
post #5 of 12 Old 10-23-2013, 09:40 AM
djwrangler
1997 XJ Cherokee
Depends how you wheel really but the general consensus is that the Dana 30 is fine with 33s.
djwrangler is offline
post #6 of 12 Old 10-23-2013, 01:38 PM
Apollo12227
The dana 30 can easily handle 33's.
Apollo12227 is offline
post #7 of 12 Old 10-24-2013, 06:56 AM
95YamJam
I run 36's on my d30. All stock. No issues so far.
Daily driven and wheeled.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline
post #8 of 12 Old 10-27-2013, 02:29 PM
1998zj
I have 4.5 inches of lift and I run 35's with the Dana 30.
1998zj is offline
post #9 of 12 Old 10-27-2013, 02:44 PM
squarelite
The hp 30. Is a lot stronger than people give it credit for.
squarelite is offline
post #10 of 12 Old 10-28-2013, 08:30 PM Thread Starter
Benzfrd
Thanks guys I appreciate the info. I am gonna keep it and just put in the new axle shaft. That and save up for the 8.8 rear I was thinking of going with. I was looking online and seen some ok prices. You guys have any tips on how to get on for cheap?
Benzfrd is offline
post #11 of 12 Old 10-28-2013, 09:10 PM
Apollo12227
Junkyard.
post #12 of 12 Old 11-04-2013, 02:51 PM
jeepguy85
1987 YJ Wrangler
Craigslist
Originally Posted by Exparrot View Post
"When Chuck Norris drives, Chuck Norris controls the radio..."
Originally Posted by HurricaneRZA View Post
Mean Max created Chuck Norris with some spare parts, two trac bars and some differential fluid.
jeepguy85 is offline
