Rear Axle Question - JeepForum.com
post #1 of 6 Old 05-01-2001, 05:26 PM Thread Starter
Loomis4wheeler
Rear Axle Question
My current config:87' spring over,35rear with 4:56 gears and lock right lockers, 33" tires.I'm starting to wonder if I made a mistake investing in current 35 rear axle. Question: Am I on borrowed time with this rear end, I realize everything can break,however, I have one shop telling me to replace it and another saying don't worry. I just spent the money on this setup last summer, so not excited about replacing. Any thoughts?
Loomis4wheeler is offline
post #2 of 6 Old 05-01-2001, 06:11 PM
Tonka
2015 JK Wrangler
Take it easy on the 35 rear... especially with lockers. I have a 95 yj , 31in BFG muds with the dana 35c rear and a lockright. Two days after the locker was installed, I broke the passenger side axle shaft.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 6 Old 05-01-2001, 10:58 PM
Cody_91YJ
With 33s, I'd think you should be ok...just don't go crazy on the throttle off-road.
I run 35s with 4.56 gears, lockers, and wheel pretty hard...still not broken (knock on wood ).
But I've got a Ford 8.8 to swap in as soon
as I save a few more bucks.
If you go bigger then 33s, I'd consider an upgrage. Either the Superior Axle Super 35C kit...or an axle swap. The axle swap may even be cheaper, or close to the Super 35C.
Even so, you may start putting aside spare cash to prepare for the next upgrade
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #4 of 6 Old 05-02-2001, 11:34 AM
rayray
rayray's Avatar
Loomis,
Check out Superior's dana 35 options. The super 35 kit is a nice setup with never a reported broken axle. They also have a nice warrenty. I've been very happy with mine. My only grip is it's an act of God to get a spare shaft(s). An axle truss isn't a bad idea either.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #5 of 6 Old 05-02-2001, 11:20 PM
osburn
osburn's Avatar
I bought my 95 YJ in September of 94. Up until last July I was running on the stock axles. The last setup I ran on those axles was an SOA, ARBs, 4.10s and 33" tires. My wheeling on those axles included the Rubicon a few times, the Dusy-Ershim, even Jackhammer at Johnson Valley among lots of other trails and events. I have never busted so much as a u-joint. It's my opinion, if you can't afford to do an axle swap, but you can afford to get locked and geared, do it! I wouldn't spend the dough on these new ultra-shafts from various vendors. Just getting spares for the ones you have is a better investment. For now, run what ya brung! Later down the road when you can afford and believe you really need an axle swap, then go for it. ARBs were expensive, but I sure as hell don't figure I wasted my money putting them into stock axles. I got my money's worth out of them. Heaven forbid I would have taken the advice of not locking those axles and missed out on all the cool trails I did on them stockers.
Matt Osburn
Score 1032
osburn is offline
post #6 of 6 Old 05-03-2001, 01:07 AM
jpwranglr9
I did the same thing with my axles after a gearless didn't like where it was in the rear end. I put 4.56 with a detroit locker in the rear 35C. I use Moser shafts and broke one playing on something i shouldn't have. I did that with 35's on the jeep. with 33's you shouldnt have a problem. i ran with the same setup with 33's for 2 1/2 years and never have a problem. I would recomend getting a set of Moser shafts or Superior shafts from Lane Auto.
Its not what you buy...its what you BUILD!!!
1995 YJ ,SOA with 4" procomp front 3.5" BDS rear 1" shackle rear, custom stearing, 35x12.50x15 pro-comp MTs, warn xd9000i, on-board air from A/C, dana 44 rear and 30 front with 4.56, powertrax no-spin rear, custom disks rear/trutrac front, warn front shafts, HD SYE kit, HD front and rear driveshafts, Warn 4X flairs, PIAA 520 ligts and on and on and on :)
jpwranglr9 is offline
Rear Axle Question Noclrnce YJ Wrangler Technical Forum 3 02-10-2010 01:57 PM
Rear Brake and Rear Axle Question CheapSunglasses YJ Wrangler Technical Forum 2 05-31-2009 01:32 PM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
8.8 rear axle question medman901 YJ Wrangler Technical Forum 15 02-06-2006 03:40 PM
question about D44 rear axle josey_wales TJ Wrangler Technical Forum 1 02-12-2005 03:17 PM
