Rear Axle Pinion Seal - Dana 35 - JeepForum.com
post #1 of 5 Old 11-04-2005, 11:21 PM Thread Starter
SeattleTJ
I replaced the pinion seal on my Dana 35 the other day, I had the driveshaft off since I was taking out the tranny, so all I had to do was unbolt the pinion nut to get to the seal. The pain in the butt was getting the seal out. I tried using my harbor freight seal puller to pop it out, but succeeded only in bending and breaking the tips of it. I finally took a screwdriver and a 2lb mallet and tapped the flat edge of the screwdriver under the lip of the seal all the way around the seal until it popped out. I replaced the seal with a new one, it looked different than the old one as it had no lip on it. I put it in by holding a big socket over the pinion shaft and tapping the seal into the case. I am hoping this cures the leak.
SeattleTJ is offline
post #2 of 5 Old 08-23-2011, 08:18 AM
hunterboy2121
i just did the same thing last night but with no luck on putting the new seal in. i changed from a regular yoke to the spicer kit with u-bolts upgrade and the seals were different. the new seal seems a bit too big (the outside ring) but we jerry rigged it in mostly. the bottom is in very snug but the top is not in rite. it only leaks a little bit and i think it will do till i get another seal
hunterboy2121 is offline
post #3 of 5 Old 08-23-2011, 08:43 AM
sequel
did you properly ensure that the pinion bearing has the correct preload?
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline
post #4 of 5 Old 08-23-2011, 09:50 AM
hunterboy2121
ummm . . . it was tight
post #5 of 5 Old 09-14-2011, 09:04 AM
rogerhill
lol I forgot about this too but I lucked out.
rogerhill is offline
Rear axle seal/ Rear Pinion seal phillies4752 TJ Wrangler Technical Forum 17 02-01-2010 10:05 PM
Rear axle still leaks after pinion seal replacement. What to do now? ssl90 TJ Wrangler Technical Forum 20 10-23-2009 08:27 AM
Rear Axle Pinion Seal just replaced, still leaking Wrangler_91 TJ Wrangler Technical Forum 7 04-25-2009 10:07 PM
03 Sahara Front Axle Pinion Seal Dana 30 172heavy TJ Wrangler Technical Forum 1 01-18-2009 05:04 PM
Dana 35 rear axle seal pharmacist25 TJ Wrangler Technical Forum 2 04-25-2006 12:26 PM
