rear axle leak - JeepForum.com
post #1 of 14 Old 10-28-2013, 12:16 PM Thread Starter
fireguyl9
rear axle leak
Whenever I park at a left leaning angle I notice a leak at left rear wheel,never whenn parking flat.
There is a very small amount of up and down play in the axle.
is the seal blown or do I need to replace that side?
fireguyl9 is offline
post #2 of 14 Old 10-28-2013, 08:51 PM
gtg413i
2003 WJ
Inner axle seal. Need to remove the carrier and axles to replace. Its not worth it for a small drip. Just keep it topped off with fluid every few weeks. Or if you have a strong rear axle, upgrade gears and throw in a locker and do the seals at the same time.
Brian's Black Betty Build:
gtg413i is offline
post #3 of 14 Old 10-28-2013, 11:05 PM Thread Starter
fireguyl9
thanks for the info
post #4 of 14 Old 10-29-2013, 01:42 PM
Apollo12227
I would fix it if it were me. If there is play in the axle shaft then the outer axle bearing is gone too. The seal and the bearing are near the end of the axle tube. There is no "inner seal" near the differential on the d35.
Apollo12227 is offline
post #5 of 14 Old 10-29-2013, 05:45 PM
idskot
.. wut? The Dana 35 only has seals at the end. Super simple to replace them, too.
All you have to do is jack up that side, remove the tire, pop open the differential cover and then push the shaft in a little (push it inward toward the differential), remove the c-clip inside of the carrier that retains the axle shaft, then slide the shaft out. That will expose the seal at the end of the tube.
Using a seal remover, pop the old one out. With either a seal setting tool, or your own DIY tool (I used a 2x4 when I did mine), hit the new one in. Put the shaft in, put the c-clip on. Clean the diff cover and housing, put a new bead of sealant on, screw it in. Fill it up. And you're good to go.
I'd do both seals at the same time. It's an extra 30 minutes or so of work, at most... and if one seal is leaking, the other one probably isn't too far behind.
idskot is offline
post #6 of 14 Old 10-30-2013, 12:16 PM Thread Starter
fireguyl9
thanks idskot, looks like I have a project to do at the fire station
post #7 of 14 Old 10-30-2013, 12:45 PM
SeanB95YJ
Just carry a short piece of scrap 6x6 with you... when you go to park, stop about 1' short of where you need, get out, place 6x6 block of wood in front of rear left wheel, then pull ahead the remaining foot. you'll never leak a drop out that side again (at least not while parked )
to me (and most of us here) that's about the only expense worth putting into the turdy-5
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #8 of 14 Old 10-30-2013, 01:45 PM
gtg413i
2003 WJ
Originally Posted by idskot
.. wut? The Dana 35 only has seals at the end. Super simple to replace them, too. All you have to do is jack up that side, remove the tire, pop open the differential cover and then push the shaft in a little (push it inward toward the differential), remove the c-clip inside of the carrier that retains the axle shaft, then slide the shaft out. That will expose the seal at the end of the tube. Using a seal remover, pop the old one out. With either a seal setting tool, or your own DIY tool (I used a 2x4 when I did mine), hit the new one in. Put the shaft in, put the c-clip on. Clean the diff cover and housing, put a new bead of sealant on, screw it in. Fill it up. And you're good to go. I'd do both seals at the same time. It's an extra 30 minutes or so of work, at most... and if one seal is leaking, the other one probably isn't too far behind.
I was thinking a front 30 sorry for misguidance.
gtg413i is offline
post #9 of 14 Old 10-30-2013, 09:46 PM
Flajeeper1
1987 YJ Wrangler
[QUOTE=SeanB95YJ;17292538]Just carry a short piece of scrap 6x6 with you... when you go to park, stop about 1' short of where you need, get out, place 6x6 block of wood in front of rear left wheel, then pull ahead the remaining foot. you'll never leak a drop out that side again (at least not while parked )
Flajeeper1 is offline
post #10 of 14 Old 10-02-2014, 09:56 AM Thread Starter
fireguyl9
i'm replacing both axles in my 95 YJ having trouble loosening the locknut on the pin
any tips?
post #11 of 14 Old 10-02-2014, 11:29 AM
mike134
I would disagree with this. If you're not doing hard offroading, there is no need to upgrade the Dana 35. Replace the seal, the part is cheap enough and you probably want to tinker with the jeep anyway. Unless you are going to climb underneath and check your diff fluid every couple days, you shouldn't wait too long.
mike134 is online now
post #12 of 14 Old 10-03-2014, 06:14 AM
Jeepsr4me
any tips?
What exactly or where exactly is the lock nut?
I can walk you thru this fix with no problems,
If you talking about the bolt that holds the cross shaft? Bolt can brreak so be mindful of which way you loosening it. Once out then the cross shaft will slide out. Then push in the axles and the C clip will be right there in the diff. Take it off and then pull axle out. the seal and bearing are toast and they are one of the easiest to get at.
GET A LOT OF BRAKE CLEAN... the oil has already contaminated the shoes.
But lets fix the leak 1st then get the brakes back to working
Jeepsr4me is offline
post #13 of 14 Old 10-03-2014, 07:20 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
any tips?
It probably has some lock tight on the threads. Use a little heat to get it loosened up.
-John-
johnboy68 is offline
post #14 of 14 Old 10-03-2014, 07:26 AM
Steve707
I broke my first 35 getting on the freeway. But a bad seal is cheap enough that replacing the axle isn't worth it right now unless you were going to anyway.
Steve707 is offline
