Rear axle bearing cap ?? - JeepForum.com
post #1 of 2 Old 04-03-2012, 05:33 AM Thread Starter
mylittlecj5
1974 CJ5
I am putting together a Jeep from used spare parts out of my shop.
I am working on the axles right now, I have a YJ mated pair with 4:10 gears and a rear L/S diff chosen for the install. My problem is that someone had decided to remove the cover off the rear axle and take the bearing caps off at one time or another, and they are no longer with the parts Jeep.
Would it screw anything up if I took a set of caps off another axle and installed them on this one? I am not axle qualified, so I'm not sure if I would have to reset the gear patterns or preloads or not. Every thing else is there to make this a bolt-in deal, I just need to find out if this axle is useable, or if I will have to put these gears in another housing.
Default Jeepers Club #10
mylittlecj5 is offline
post #2 of 2 Old 04-03-2012, 05:48 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
They are torqued down to the housing during mfg before the bearing seating surface is ground, to ensure a perfect circle for the bearing. I would not use another pair, meaning I'd say you are screwed.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
Rear Axle Bearing Play? tcmault TJ Wrangler Technical Forum 1 05-12-2011 11:01 AM
rear axle bearing mattcm88 TJ Wrangler Technical Forum 2 04-23-2011 12:44 PM
Symptoms of a bad rear axle shaft bearing? cpleasant TJ Wrangler Technical Forum 8 11-02-2010 06:30 PM
New rear axle bearing and seal melius TJ Wrangler Technical Forum 9 05-20-2009 07:09 PM
d44 rear axle bearing removal ????? cincytj TJ Wrangler Technical Forum 7 03-20-2006 04:37 PM
