rear 35 to front 35 - JeepForum.com
post #1 of 4 Old 03-04-2002, 08:34 PM Thread Starter
Jeepguy3401
rear 35 to front 35
I'm thinking about putting a Dana 44 in the rear after i get the new engine in, could I reuse the D35 for the front if I got a different axle housing or no? It might not even save me any money, I don't know, that's why i posted this question. Thanks in advance.
'87 YJ,4.2L 6cyl(rebuilding someday) On 33" Mickey Thompson Baja Claws, (unlifted, but big lift in store, when I get some $$$)upgraded clutch and brakes, broken loud stereo.(Can't imagine how that....COUGH!..WATER....happened. Haven't used a top doors or windshield in uh,.....hmm.... since midwinter? That sounds right.
Jeepguy3401 is offline
post #2 of 4 Old 03-04-2002, 10:12 PM
RodeoRob
RodeoRob's Avatar
There is no such thing as a stock Dana 35 front axle. Sure, you could make one, but I see *no* benefits in doing this... and if you're looking to save money, I can tell you this is not the way! It would be relatively expensive (even if you had the tools/knowledge to do yourself) to make a D35 into a front axle.
I should also add many consider the stock D30 to be stronger and more reliable than the D35... way replace it with something weaker. If you wanna replace the front, look to a D44... matching front/rear D44s isn't a bad combo.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 4 Old 03-04-2002, 10:48 PM Thread Starter
Jeepguy3401
Oh, well just wondered if it could be done.I guess I know. Thanks.
post #4 of 4 Old 03-04-2002, 10:59 PM
RodeoRob
RodeoRob's Avatar
Yup, could be done. You would have to shorten the drivers side and lengthen the passenger side tubes to get the diff in the correct place. You'd end up robbing knuckles (not to mention all the outers) from some other front axle (D30 or maybe D44). And of course, custom shafts. So when you're done, you'd be left with the center section of the D35 and the rest would be a D30/44.
-Rob
Robert Gorrell
RodeoRob is offline
3.07 rear Trac-Lok to 4.10 front and rear. To-do next. RUNIT TJ Wrangler Technical Forum 9 01-31-2008 08:14 PM
Is Sahara Dana 44 front and rear or just rear? Capinsano3 TJ Wrangler Technical Forum 27 01-31-2007 01:03 PM
front AND rear end in YJ demoguru YJ Wrangler Technical Forum 2 11-11-2006 01:28 PM
Front end Rear end jeepguy123 YJ Wrangler Technical Forum 0 10-03-2006 02:47 PM
4.11 front and 4.10 rear? terrible TJ Wrangler Technical Forum 9 07-08-2005 12:41 AM
