Rear ? - Page 7 - JeepForum.com
post #91 of 117 Old 01-01-2012, 05:06 PM
dillonjm
2013 WK
Originally Posted by Dave83
What do u mean the hole front end out of a cherokee or just the gears because I found a set of 3.73 on line for 147.00 not sure what it will cost to have installed.
You'll need an install kit too. Labor should be 4-500
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #92 of 117 Old 01-01-2012, 05:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It is $150 for the gears apparently and another $100 for the set up kit. Bearings and seals and shims and the like. Plus whatever the carrier costs.
Install on gears is $300 at the very cheapest you can find so you're looking at near $600 for the install vs a plug and play game on installing another axle with the gears already installed.
If you're looking to install a full carrier locker then going the first route is best.
Luck Favours The Prepared
Anticanman is offline
post #93 of 117 Old 01-01-2012, 09:17 PM Thread Starter
Dave83
Ok now I understand I haven't ever messed with this stuff so things like this have to be put in perspective lol so back to looking for an axle. Were you saying a Cherokee axle will work in it we have alot more of those around here would make this alittle easier.
Dave83 is offline
post #94 of 117 Old 01-01-2012, 09:25 PM Thread Starter
Dave83
I am looking on that car parts.com website the wrecking yards around here are wantin 600 for a used axle with 4.10 gears!
Dave83 is offline
post #95 of 117 Old 01-01-2012, 09:28 PM
94chb
DANG!! lol ANY rear end here is only $100 and any Complete Front end is $200
94chb is offline
post #96 of 117 Old 01-01-2012, 09:29 PM Thread Starter
Dave83
And I am going to have to travel 4 hrs.
Dave83 is offline
post #97 of 117 Old 01-01-2012, 09:30 PM Thread Starter
Dave83
I seen that and about lost it, was wondering where u gays were getting ur numbers lol
Dave83 is offline
post #98 of 117 Old 01-01-2012, 09:31 PM Thread Starter
Dave83
They are wanting 800 for a rear end damn lol wrong part of the country to own a jeep
Dave83 is offline
post #99 of 117 Old 01-01-2012, 09:32 PM
94chb
heres my PULL-A-PART Parts list
Description Price Core
4 CYLINDER ENGINE $130.00 $20.00
4X4 AXLE W/O HUBS $125.00 $0.00
6 CYLINDER ENGINE $155.00 $20.00
8 CYLINDER ENGINE $180.00 $20.00
A FRAME CONTOL ARM $20.00 $0.00
A/C CLUTCH $12.50 $0.00
A/C COMPRESSOR $20.00 $5.00
A/C CONDENSER $14.00 $3.00
A/C DRYER $8.00 $0.00
A/C DUCT $7.00 $0.00
A/C EVAPORATOR $23.00 $2.00
A/C HOSE $10.00 $0.00
A/C SUITCASE HOUSING $10.00 $0.00
A/C VACUUM VALVE $4.00 $0.00
A/C VENT $3.00 $0.00
AIR BAG (EACH) $40.00 $0.00
AIR CLEANER HOUSING $10.00 $0.00
AIR CLEANER LID $5.00 $0.00
AIR FILTER $2.00 $0.00
AIR FLOW METER $20.00 $0.00
AIR RIDE COMPRESSOR $24.00 $0.00
ALTERNATOR $17.00 $3.00
ANTENNA/MANUAL $4.00 $0.00
ANTENNA/POWER $11.00 $0.00
ASH TRAY $4.00 $0.00
AXLE SHAFT SOLID $25.00 $0.00
BACK GLASS $35.00 $0.00
BATTERY (USED) $25.00 $5.00
BATTERY BOX $5.00 $0.00
BATTERY CABLE $4.00 $0.00
BCKT SEAT CLOTH/VINY $25.00 $0.00
BEARING (ANY) $4.00 $0.00
BED LINER $25.00 $0.00
BED RAIL $7.50 $0.00
BELLHOUSING $25.00 $2.00
BENCH SEAT $40.00 $0.00
BOLTS-NUTS-SCREWS $0.10 $0.00
BRACKET ANY $0.40 $0.00
BRAKE 3RD LIGHT ASSY $6.00 $0.00
BRAKE ABS CONTROLLER $42.00 $0.00
BRAKE BSTR $11.00 $0.00
BRAKE CALIPER $12.00 $0.00
BRAKE DRUM $10.00 $0.00
BRAKE EMERGENCY CABL $8.00 $0.00
BRAKE MASTER CYLINDE $12.00 $0.00
BRAKE PROPORTIONING $7.00 $0.00
BRAKE RESEVOIR $5.00 $0.00
BRAKE ROTOR $12.00 $0.00
BRAKE SHOE/PAD (EA) $1.00 $0.00
BRAKE SPRING/HARDWAR $1.50 $0.00
BRAKE WHEEL CYCLINDE $4.00 $0.00
BRUSH GUARD $30.00 $0.00
BUCKET SEAT LEATHER $35.00 $0.00
BUG DEFLECTOR $8.00 $0.00
BULBS $0.50 $0.00
BUMPER ABSORBER $9.00 $0.00
BUMPER ANY BARE $40.00 $0.00
BUMPER COVER $23.00 $0.00
BUMPER END CAP $5.00 $0.00
BUMPER GUARD $10.00 $0.00
BUMPER REINFORCEMENT $15.00 $1.99
CABLE (ANY) $5.00 $0.00
CAMPER SHELL COMPACT $75.00 $0.00
CAMPER SHELL OEM $150.00 $0.00
CAMSHAFT $15.00 $0.00
CAP (OIL, GAS, WATER $3.00 $0.00
CARB CHOKE STOP $3.00 $0.00
CARBURETOR $22.00 $3.00
CARPET $7.00 $0.00
CART RENTAL $3.00 $0.00
CIGARETTE LIGHTER $2.00 $0.00
CLOCK & SMALL GUAGES $5.00 $0.00
CLUTCH DISC $15.00 $0.00
CLUTCH FORK $7.00 $0.00
CLUTCH MSTR CYLINDER $10.00 $0.00
CLUTCH PRESSURE PLAT $15.00 $0.00
CLUTCH RESEVOIR $5.00 $0.00
CLUTCH SLAVE CYL $12.00 $0.00
CMPR SHELL FULL SIZE $100.00 $0.00
CMSHFT OVERHEAD TYPE $25.00 $0.00
COIL IGNITION $8.00 $0.00
COIL PACK $15.00 $0.00
COIL SPRING $5.00 $0.00
COIL W/ IGNITOR $15.00 $0.00
COMPUTER BRAIN BOX $30.00 $0.00
COMPUTER MODULE $15.00 $0.00
CONSOLE (ANY) $15.00 $0.00
CONSOLE LID $5.00 $0.00
CRANKSHAFT $30.00 $0.00
CROSSMEMBER $20.00 $0.00
CRUISE CONTROL UNIT $15.00 $0.00
CUP HOLDER $3.00 $0.00
CV AXLE FRNT DRIVE $30.00 $0.00
DASH ASSEMBLY COMPLE $55.00 $0.00
DASH PAD $22.00 $0.00
DIPSTICK OR TUBE $4.00 $0.00
DIST CAP GM HEI $10.00 $0.00
DISTRIBUTOR $25.00 $0.00
DISTRIBUTOR CAP $5.00 $0.00
DISTRIBUTOR GM HEI $35.00 $2.00
DOG HOUSE $20.00 $0.00
DOME LIGHT $3.00 $0.00
DOME LIGHT COVER $2.00 $0.00
DOOR $40.00 $0.00
DOOR ARM REST $6.00 $0.00
DOOR GLASS $15.00 $0.00
DOOR HANDLE INTERIOR $3.00 $0.00
DOOR HANDLE OUTSIDE $8.00 $0.00
DOOR PANEL $15.00 $0.00
DOOR-SLIDING VAN $45.00 $0.00
DR MIRROR GLASS ONLY $5.00 $0.00
DRIVE SHAFT $20.00 $0.00
DROP OUT 3RD MBR $65.00 $0.00
EGR VALVE (EACH) $8.00 $0.00
ELECTRIC FAN DUAL $25.00 $0.00
ELECTRIC FAN SING $20.00 $0.00
EMBLEM (ANY) $3.00 $0.00
ENGINE BLOCK $65.00 $10.00
ENGINE CRADLE $65.00 $0.00
EXH. MANI (NO 02) $20.00 $0.00
EXHAUST PIPE $1.50 $0.00
FAN BELT $1.00 $0.00
FAN CLUTCH $10.00 $0.00
FAN SHROUD $8.00 $0.00
FENDER BARE $35.00 $0.00
FENDER INNER $10.00 $0.00
FENDER SKIRT/TRIM/FL $7.00 $0.00
FLOOR MAT $2.00 $0.00
FLYWHEEL $15.00 $0.00
FOG LAMP $8.00 $0.00
FRNT AXLE BEAM TYPE $70.00 $0.00
FRONT AXLE ASSY 4X4 $200.00 $0.00
FUEL INJECTION PUMP $35.00 $0.00
FUEL INJECTION RAIL $15.00 $0.00
FUEL INJECTOR (EACH) $6.00 $0.00
FUEL PRES REGULATOR $10.00 $0.00
FUEL PUMP ELECTRIC $18.00 $0.00
FUEL PUMP MANUAL $10.00 $0.00
FUEL SNDR WITH PUMP $23.00 $0.00
FUEL TANK SND UN $12.00 $0.00
FUEL TANK STRAP $4.00 $0.00
FUSE BOX BARE $12.00 $0.00
GAS CAP DOOR $5.00 $0.00
GAS FILLER TUBE $10.00 $0.00
GAS PEDAL $5.00 $0.00
GATE FEE $2.00 $0.00
GLOVE BOX DOOR $10.00 $0.00
GLOVE BOX INSERT $4.00 $0.00
GRILLE ANY $25.00 $0.00
GRND EFF. (EACH SIDE $20.00 $0.00
HARMONIC BALANCER $15.00 $0.00
HATCH GLASS $25.00 $0.00
HATCH WITH GLASS $50.00 $0.00
HATCH/HOOD SHOCK $5.00 $0.00
HEAD REST $5.00 $0.00
HEAD WITH CAM $55.00 $5.00
HEAD WITHOUT CAM $40.00 $5.00
HEADERPANEL BARE $30.00 $0.00
HEADLIGHT ASSY DUAL $25.00 $0.00
HEADLIGHT ASSY SINGL $20.00 $0.00
HEADLIGHT BEZEL $10.00 $0.00
HEADLIGHT DOOR $15.00 $0.00
HEADLIGHT LENS $10.00 $0.00
HEADLIGHT MOTOR $15.00 $0.00
HEADLINER $15.00 $0.00
HEATER AIR DUCT $2.00 $0.00
HEATER ASSY COMPLETE $45.00 $0.00
HEATER CONTROL VALVE $5.00 $0.00
HEATER CORE $14.00 $2.00
HEATER CTRL DIGITAL $20.00 $0.00
HEATER CTRL MANUAL $10.00 $0.00
HEATER FAN W/O MOTOR $5.00 $0.00
HEATER HOUSING $10.00 $0.00
HEATER MOTOR $13.00 $2.00
HEATER MOTOR W/ FAN $18.00 $0.00
HINGE-ANY $5.00 $0.00
HOOD $40.00 $0.00
HOOD SCOOP $15.00 $0.00
HORN $5.00 $0.00
HORN COVER $5.00 $0.00
HOSE $0.15 $0.00
HUB $10.00 $0.00
HUB CAP $5.00 $0.00
HUB CAP CENTER CAP $5.00 $0.00
HUB LOCKING TYPE 4X4 $30.00 $0.00
IDLER ARM $10.00 $0.00
IGNITION SWITCH $6.00 $0.00
INS CLSTR CIR BOARD $10.00 $0.00
INSTR CLSTR LENS $12.00 $0.00
INSTRUMENT CLUSTER $25.00 $0.00
INT. PANEL (OVER 12" $10.00 $0.00
INT. PANEL (UNDER 12 $5.00 $0.00
INTK MANI INLINE 4/6 $20.00 $0.00
INTK MANI V6/V8 $35.00 $0.00
JACK ANY $5.00 $0.00
JACK HANDLE $1.00 $0.00
JUMPER CABLES $2.00 $0.00
KNOB $2.00 $0.00
LADDER $15.00 $0.00
LATCH $6.00 $0.00
LEAF SPRING $20.00 $0.00
LICENSE PLATE BRACKE $5.00 $0.00
LOCK TUMBLER $5.00 $0.00
LOUVERS $20.00 $0.00
LUG NUT $1.00 $0.00
LUG WRENCH $4.00 $0.00
LUGGAGE RACK $20.00 $0.00
LUMBER/PIPE RACK $40.00 $0.00
MARKER LIGHT / SIDE $2.00 $0.00
MIRROR - DOOR $15.00 $0.00
MOLDING EXTERIOR $0.20 $0.00
MOTOR MOUNT $8.00 $0.00
MUFFLER (ANY) $12.00 $0.00
OIL FILTER $2.00 $0.00
OIL FILTER HOUSING $7.00 $0.00
OIL PAN $17.00 $0.00
OIL PUMP $10.00 $0.00
OVERFLOW BOTTLE $4.00 $0.00
OWNERS MANUAL $4.00 $0.00
PARK/TURN LIGHT ASSY $10.00 $0.00
PARKING LIGHT LENS $4.00 $0.00
PEDAL (BRAKE/CLUTCH) $10.00 $0.00
PEDAL ASSEMBLY $20.00 $0.00
PICKUP BED WITH TAIL $225.00 $0.00
PICKUP BED WITHOUT T $195.00 $0.00
PICKUP CAB W/ DOORS $300.00 $0.00
PICKUP CAB W/O DOORS $230.00 $0.00
PISTON & ROD $15.00 $1.00
PITMAN ARM $10.00 $0.00
POWER STEERING PUMP $20.00 $4.00
PULLEY BARE $5.00 $0.00
PUMP FEE - CAR $10.00 $0.00
PUMP FEE - TRUCK $20.00 $0.00
PUSH ROD $2.50 $0.00
QUARTER GLASS $15.00 $0.00
QUARTER PANEL $50.00 $0.00
QUARTER PANEL TRIM $7.00 $0.00
RACK & PINION $35.00 $5.00
RADIATOR $30.00 $10.00
RADIATOR CORE SUPPOR $35.00 $0.00
RADIATOR FAN MANUAL $15.00 $0.00
RADIO $15.00 $0.00
RADIO BEZEL $4.00 $0.00
RADIO WITH CD PLAYER $22.00 $0.00
REAR AXLE ASSY FWD $85.00 $0.00
REAR END COVER $8.00 $0.00
REAR END CRRIER ASSY $55.00 $0.00
REAR END HSNG BARE $40.00 $0.00
REAR END PINION GEAR $30.00 $0.00
REAR END RING GEAR $30.00 $0.00
REAR END SPYDER GEAR $10.00 $0.00
REAR END W/DISCS $150.00 $0.00
REAR END W/O DRUMS $80.00 $0.00
REAR END WITH DRUMS $100.00 $0.00
REAR END YOKE $10.00 $0.00
REAR GLASS $35.00 $0.00
REARVIEW MIRROR $5.00 $0.00
RELAY (EACH) $2.00 $0.00
ROCKER ARM $4.00 $0.00
ROTOR BUTTON $3.00 $0.00
RUNNING BOARD $15.00 $0.00
SEAT BELT $8.00 $0.00
SEAT BELT END/CONNEC $5.00 $0.00
SEAT COVER $5.00 $0.00
SEAT MOTOR $15.00 $0.00
SEAT PEDESTAL $8.00 $0.00
SEAT REAR PER SECTIO $10.00 $0.00
SEAT TRACKS $8.00 $0.00
SENSOR (EMMISSIONS) $10.00 $0.00
SENSOR (OIL/WATER) $3.00 $0.00
SHIFTER $15.00 $0.00
SHIFTER BOOT $2.00 $0.00
SHIFTER KNOB $3.00 $0.00
SHOCK ABSORBER $8.00 $0.00
SILL PLATE $4.00 $0.00
SLIDING GLASS WINDOW $30.00 $0.00
SMOG CANISTER $7.00 $0.00
SMOG PUMP $25.00 $0.00
SMOG VALVE $10.00 $0.00
SPARE TIRE CARRIER $15.00 $0.00
SPARE TIRE COVER $5.00 $0.00
SPARK PLUG OR WIRE $1.00 $0.00
SPEAKER 5"-10" $8.00 $0.00
SPEAKER COVER $1.50 $0.00
SPEAKER OVER 12" $12.00 $0.00
SPEAKER UNDER 5' $4.00 $0.00
SPEEDOMETER $10.00 $0.00
SPINDLE $20.00 $0.00
SPOILER $15.00 $0.00
STABALIZER BAR $7.00 $0.00
STARTER $18.00 $3.00
STARTER SOLENOID $5.00 $0.00
STEEL LINE $0.20 $0.00
STEERING BOX $25.00 $0.00
STEERING COUPLER $7.00 $0.00
STEERING RESEVOIR $5.00 $0.00
STEERING SHAFT $10.00 $0.00
STEERING WHEEL COVER $4.00 $0.00
STRNG CLMN W/AIRBAG $55.00 $0.00
STRNG CLMN W/O AIRBA $40.00 $0.00
STRNG WHL W/AIRBA $40.00 $0.00
STRNG WHL W/O AIR $15.00 $0.00
STRUT MCPHERSON $25.00 $0.00
SUN VISOR $5.00 $0.00
SUNROOF ASSEMBLY $35.00 $0.00
SUNROOF GLASS $20.00 $0.00
SWAY BAR $15.00 $0.00
SWITCH COMBO $9.00 $0.00
SWITCH SINGLE $4.00 $0.00
SWITCH TURN SIGNAL $10.00 $0.00
TACHOMETER $10.00 $0.00
TAIL GATE $35.00 $0.00
TAIL LIGHT ASSEMBLY $15.00 $0.00
TAIL LIGHT LENS $8.00 $0.00
TENSIONER PULLEY $12.00 $0.00
THERMOSTAT $2.00 $0.00
THERMOSTAT HOUSING $5.00 $0.00
THROTTLE BODY $35.00 $0.00
THROWOUT BEARING $5.00 $0.00
TIE ROD ASSY $15.00 $0.00
TIE ROD END $8.00 $0.00
TIMING CHAIN $8.00 $0.00
TIMING GEAR $4.00 $0.00
TIMING GEAR CVR ALUM $8.00 $0.00
TIRE $15.00 $0.00
TIRE SPARE $10.00 $0.00
TMG GEAR CVR FE/PLAS $5.00 $0.00
TOP CONVERTIBLE $100.00 $0.00
TOP CONVERTIBLE MTR $35.00 $0.00
TOP CONVERTIBLE RAM $30.00 $0.00
TORQUE CONVERTER $25.00 $0.00
TORSION BAR $10.00 $0.00
TRAILER HITCH (NO BA $12.00 $0.00
TRAILER HITCH BALL $5.00 $0.00
TRAILERHITCH RECEIVE $30.00 $0.00
TRAILING ARM $10.00 $0.00
TRANS COVER/SHIELD $5.00 $0.00
TRANS DIPSTICK $4.00 $0.00
TRANS OIL COOLER $10.00 $0.00
TRANS TAIL HOUSING $15.00 $0.00
TRANS VALVE BODY $25.00 $0.00
TRANSFER CASE ( 4X4) $90.00 $10.00
TRANSMISSION $85.00 $15.00
TRANSMISSION CASING $40.00 $0.00
TRANSMISSION FILLER $4.00 $0.00
TRANSMISSION MOUNT $8.00 $0.00
TRANSMISSION PAN $5.00 $0.00
TRUNK LID NO LIGHTS $22.00 $0.00
T-TOP $35.00 $0.00
TURBO CHARGER $60.00 $0.00
TURBO INTERCOOLER $25.00 $0.00
U-BOLT $3.00 $0.00
U-BOLT PLATE $5.00 $0.00
U-JOINT $5.00 $0.00
VACUUM CANISTER/BALL $5.00 $0.00
VACUUM PUMP $20.00 $0.00
VALANCE PANEL $15.00 $0.00
VALVE COVER ALUMINUM $15.00 $0.00
VALVE COVER STEEL $7.50 $0.00
VENT GLASS $12.00 $0.00
VENT PANEL COWL $15.00 $0.00
VOLTAGE REGULATOR $8.00 $0.00
WATER PUMP $12.00 $2.00
WEATHERSTRIPPING $1.00 $0.00
WHEEL ADAPTER $5.00 $0.00
WHEEL ALUMINUM $15.00 $10.00
WHEEL STEEL $10.00 $0.00
WIND. WASHER BOTTLE $5.00 $0.00
WINDOW CRANK HANDLE $3.00 $0.00
WINDOW MOTOR $15.00 $0.00
WINDOW REGULATOR $15.00 $0.00
WINDSHIELD $40.00 $0.00
WINDSHIELD WIPER ARM $5.00 $0.00
WINDSHIELD WIPER MTR $15.00 $0.00
WINSHIELD WIPER LINK $8.00 $0.00
WIRING HARNESS $2.50 $0.00
WSHR BOTTLE MOTOR $5.00 $0.00
YOKE $8.00 $0.00
94chb is offline
post #100 of 117 Old 01-01-2012, 09:49 PM Thread Starter
Dave83
U have a wrecking yard? Shipping is what kills me when getti g it that far.
Dave83 is offline
post #101 of 117 Old 01-01-2012, 10:22 PM
94chb
i dont own it lol, its the one i goto. things are dirt cheap here.
94chb is offline
post #102 of 117 Old 01-02-2012, 01:46 AM Thread Starter
Dave83
Would a Dana 35 with 4.10s be stout enough for those 34s I have on the jeep?
Dave83 is offline
post #103 of 117 Old 01-02-2012, 08:03 AM
oldtime_ironman
Not necessarily. Different gears won't make the D35 any stronger. You would be far better off to get a ford explorer ot ranger pickup rear, and a matching front off a XJ cherokee.
oldtime_ironman is offline
post #104 of 117 Old 01-02-2012, 09:43 AM
94chb
4.10 ring and pinion isnt gonna help when your breaking spider gears.
the front dana 30 will be fine.
94chb is offline
post #105 of 117 Old 01-02-2012, 09:52 AM
Quail
Nope, I broke a side gear on a 4.10 d35 while flexing it in my back yard.
Quail is offline
