Rear ? - Page 6 - JeepForum.com
post #76 of 117 Old 12-30-2011, 02:01 AM Thread Starter
Dave83
The spider gears again and this time seriously I was just driving down the road haven't had it off road or anything was scared tell I replaced the axles. Lol time to go bigger.
Dave83 is offline
post #77 of 117 Old 12-30-2011, 09:32 AM
jeep108
Like mentioned before try car-part.com for an 8.8 in your area. You can get one in 3.08 to match your front or throw a 3.73 or 4.10 version in there and disconnect (or don't use) your 4 wheel drive until you can get the front swapped. If you go w/ 4.10's and have the right tires you'll probably only need 4wd to show off
Try this
http://www.car-part.com/cgi-bin/sear...erPage=1&iKey=
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #78 of 117 Old 12-30-2011, 11:38 AM Thread Starter
Dave83
Would 3.73 be any good or not much better all the wrecking yards I call around here have the 3.73 in abundance. But I dang sure want to do it right so if no then tell me no.
Dave83 is offline
post #79 of 117 Old 12-30-2011, 11:40 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It never hurts as long as its two wheel drive. You'll have to change the front ring and pinion to match eventually but a two wheel drive on the road is better than any four wheel drive on jackstands!
Luck Favours The Prepared
Anticanman is offline
post #80 of 117 Old 12-30-2011, 11:48 AM
jeep108
Probably not going to see much difference between the 3.73 and 4.10 unless your doing a lot of climbing but here's your problem which is what i'm going thru now....
The 8.8 3.73 are more abundant here as well but when it comes time to swap out the front, the d30 with 4.10's are easier to come by than the ones with 3.73. So if your luck is like mine either way you go will wind up being like a kick in the juevos
jeep108 is offline
post #81 of 117 Old 12-30-2011, 12:43 PM Thread Starter
Dave83
Lol ok I guess I will stick withe looking for the 4.10 thanks.
Dave83 is offline
post #82 of 117 Old 12-30-2011, 01:05 PM
roadyrob
1987 YJ Wrangler
if you do decide on the 3.73 the yj used this ratio in the 94-95 4cyl automatics. they can be found on car-part.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #83 of 117 Old 12-31-2011, 07:48 AM Thread Starter
Dave83
Cool thanks for the info.
Dave83 is offline
post #84 of 117 Old 12-31-2011, 04:42 PM Thread Starter
Dave83
Can I change the gears out in the Dana 30 front end if I run 3.73s
Dave83 is offline
post #85 of 117 Old 12-31-2011, 04:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Gears and carrier, yes.
post #86 of 117 Old 12-31-2011, 06:03 PM Thread Starter
Dave83
So what would be the point in replacing the hole front end if I can just change the gears?
Dave83 is offline
post #87 of 117 Old 12-31-2011, 07:03 PM
oldtime_ironman
Cuz you can buy the whole front end for the same cost as the gears. And its way easier to do that, than it is to setup the gears properly. That's why everybody was hinting to get a ford 8.8 rear with the gears you want, and a YJ front end to match. And if you pay somebody else to do the work, it'll cost at least 2x as much.
oldtime_ironman is offline
post #88 of 117 Old 12-31-2011, 07:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
^^. Yup cost. It's cheaper believe it or not to swap the whole front end.
post #89 of 117 Old 01-01-2012, 09:55 AM
94chb
you can get the front matching gears from a cherokee also.
94chb is offline
post #90 of 117 Old 01-01-2012, 05:04 PM Thread Starter
Dave83
What do u mean the hole front end out of a cherokee or just the gears because I found a set of 3.73 on line for 147.00 not sure what it will cost to have installed.
Dave83 is offline
