Really Need Some Help Here..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Really Need Some Help Here.....
Savvy/Currie Aluminum Control ArmsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO December Specials at Jeephut.com
Unread 11-22-2014, 05:50 PM   #1
vetteonr
My '95 YJ's computer went bad and had it rebuilt but it still doesn't work. There is no stickers or markings on it so I can find a suitable replacement. Any ideas on what to do next?
"The road of life should be a two-track"
vetteonr is offline   Reply With Quote Quick reply to this message
Unread 11-22-2014, 06:22 PM   #2
Mark05059
go to a junkyard and pick up any computer from a 92 to 95 4.0 cherokee or yj. they are all the same.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2014, 09:15 PM   #3
Why J?
I have a 93 4.0 ECU in my garage not doing anyone any good you can have for the cost of shipping if it will get you back up and running.
Text me. 865-591-9116
Why J? is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 01:00 AM   #4
mike134
how did the ECU "go bad"? what are the symptoms? How was it rebuilt?
mike134 is offline   Reply With Quote Quick reply to this message
Unread 11-23-2014, 09:29 AM   #5
vetteonr
The capacitors go bad after a while. When the weather gets cold, they don't do what they are supposed to do. If you put a light bulb next to the computer it fires right up. Rebuilding is just replacing the capacitors.
Unread 11-23-2014, 09:35 AM   #6
vetteonr
Sent you a PM.
Unread 11-23-2014, 11:38 AM   #7
mike134
I see, it sounds like the capacitors weren't replaced properly. The easiest mistake is to put one in backwards. Why not pull it and see if that is the case?
Unread 11-23-2014, 11:47 AM   #8
vetteonr
I've already checked it and they are in correctly. Sometimes during the process other things can go wrong, or there might be something else wrong altogether. At this point I think I just want to replace it completely.
Unread 11-24-2014, 02:11 AM   #9
Gausswave
What method did you use to determine it's bad? The CEL or some thing else?
Gausswave is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 05:11 PM   #10
vetteonr
Because when the weather got colder (40 degrees or colder) the capacitors would fail. By putting a light bulb next to it, warming it up, it works fine.
Unread 11-29-2014, 09:03 AM   #11
vetteonr
Special thanks and a big Jeep wave to Why J? on here. He really saved my bacon on this issue. It's guys like him that restore my faith in humanity. I salute you sir.
