a really annoying problem - JeepForum.com
post #1 of 10 Old 04-22-2010, 02:34 PM Thread Starter
jeep16
hello, got my first jeep back in november. haven't even driven it yet, was mechanically pretty messed up and an still in the process of rebuilding it. the PO was a real crack job mechanic. my current problem is the plate that goes between the transmission and engine. the bottom part of it is missing, so i am able to see the torque converter and starter wheel. is this plate one piece and had a part cut out, or was it 2 pieces. it is a 1990, 4.2 auto. thanks.
jeep16 is offline
post #2 of 10 Old 04-22-2010, 05:41 PM
Axl Jack
Are you talking about the plate that goes between the bell housing and the engine? I think its called the clutch housing spacer or something. Take a pic for us so we can help you out further.
This may be what you are talking about: Jeep Wrangler YJ,TJ manual transmission shield, 88-01 : eBay Motors (item 290420013536 end time Apr-29-10 18:33:37 PDT)
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #3 of 10 Old 04-22-2010, 05:59 PM Thread Starter
jeep16
its like that, except mine is an auto.
jeep16 is offline
post #4 of 10 Old 04-22-2010, 06:01 PM
yoter
it's 1 piece, it's just a dust cover
yoter is offline
post #5 of 10 Old 04-22-2010, 06:02 PM
xdgt03
You need it especially if you are going to go offroad. If you only drive it on the street you may never have a problem but if you get into dirt, rocks, branches, weeds, mud, etc... you will need one.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #6 of 10 Old 04-22-2010, 06:03 PM Thread Starter
jeep16
great, so now I'm going to have to drop the tranny to replace it.
jeep16 is offline
post #7 of 10 Old 04-22-2010, 06:58 PM
ZeroGravity
Always double check before you put it back together
Sorry dude, it happens to everyone
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #8 of 10 Old 04-22-2010, 06:59 PM
nj95yj
i dont think you'll have to drop it just take all bolts out and slide it back just enought to shimmy the plate in. Should just slide into the bottom half
One lovely blue 97' with 33's and 4 pissed off hamsters under the hood
nj95yj is offline
post #9 of 10 Old 04-22-2010, 07:10 PM
dadstoys2
1987 YJ Wrangler
I am pretty sure that that is 1 piece and has to go in before the trans is bolted in. Just did a tranny swap, I really should know but cant remember.
~Rich
87 Wrangler Ford 302
2"bodylift 5"suspension 35" bfg A/Ts
Np435 trans w/ np205
dadstoys2 is offline
post #10 of 10 Old 04-22-2010, 07:30 PM
Burnerman
Burnerman's Avatar
The auto has a 2 piece plate. There is a large aluminum plate behind the flex plate and it ends just below the 2 "ears" on the engine block. There is a smaller inspection plate that goes on the bottom portion of the bellhousing. The plate is ther so you can unbolt the torque converter from the flex plate. It's made of stamped tin. You don't need to pull the trans to put that plate on.....
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
Minor but annoying electrical problem Cross YJ Wrangler Technical Forum 1 04-06-2008 05:06 PM
another annoying problem blacksvt YJ Wrangler Technical Forum 7 03-04-2008 02:05 PM
Vibes: annoying or real problem? FutureJK TJ Wrangler Technical Forum 5 02-07-2006 05:26 PM
Help with an annoying problem... saint matthew TJ Wrangler Technical Forum 8 07-08-2004 07:32 AM
little annoying brake problem Joe jeep YJ Wrangler Technical Forum 4 05-29-2003 07:34 AM
