Quantcast RE Spring Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > RE Spring Questions
Old 01-30-2006, 11:58 AM   #1
oct7brian
RE Spring Questions
Just got a set of RE 4" lift springs to replace my Rough Country springs. I have a few questions prior to installation. (1) are RE springs all the same front and back? (2) they do not have a shims for the rear can I just swap the shim over from my RC springs?
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline   Reply With Quote
Old 01-30-2006, 12:19 PM   #2
StCloudMNSahara
Front lift springs have 6 leafs, rear only 5,
This was the case for my RE4.5
Assuming your old RC springs are also 4", you can reuse your shims!
StCloudMNSahara is offline   Reply With Quote
Old 01-30-2006, 12:27 PM   #3
oct7brian
Yup my old RC have shims and they have worked great no vibes at all.
Thanks for the info!!
Old 01-30-2006, 12:30 PM   #4
oct7brian
OK so all 4 springs have 5 leafs. So I'm guessing they are all the same
Old 01-30-2006, 04:31 PM   #5
oct7brian
Bump
Old 01-30-2006, 04:46 PM   #6
D-train
yes, the 4in spings are all 5 leafs. it states on thier site can be used for front and rear.
D-train is offline   Reply With Quote
Old 01-30-2006, 04:48 PM   #7
TellyDSP
Poland and PPV!!!!
They should be. Measure the length of the spring(eye to eye). I recall when I was looking at springs, that the front or back were longer than the other. Otherwise they should be the same.
-Craig-
95 Rio Grande
07 Ram 1500
SIRA4x4 Club
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline   Reply With Quote
Old 01-30-2006, 06:00 PM   #8
oct7brian
Looked them over a little closer and found they all have the same part number so they are all the same... now just got to get some different shackles
Glock Forum
