RE hack and tap sye leaking around drive flange/splines - JeepForum.com
post #1 of 3 Old 11-09-2012, 07:48 AM Thread Starter
CDW_327
Ok I installed the RE H&T tonight, cut the shaft per RE instructions to 1 1/4". I had to use the seal flange because I have a YJ and they have the early T case, everything went well, took it for a test drive and when I got back home I looked under the jeep to check things I saw a drip of ATF coming from the splines of the shaft where the 3/8 bolt that holds the drive flange on. I didn't put any RVT on the splines of the shaft or the bolt, the instructions didn't say anything about it.
Putting RVT on the drive flange and splines seems like it would solve the problem, just wanting to see if anyone else had this problem and how you fixed it.
Leak
CDW_327 is offline
post #2 of 3 Old 11-09-2012, 08:16 AM
TSEJEEPERS
The RTV will not hurt anything give it a try.
Also why you have it out check the seal and make sure the spring is still there.
You may also want to pack the seal with grease.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 3 Old 11-09-2012, 08:21 AM Thread Starter
CDW_327
Yeah that's what I figured. The seal is good and there are no leaks around the seal at all, it leaks out of the splines where the drive shaft bolts to the flange.... The drive flange does fill up with ATF so I see why it would be leaking there now, just the dumb RE instructions didn't say anything about putting RVT there...
I'll try it and see what happens.
CDW_327 is offline
