re-gear worth the cost? - JeepForum.com
post #1 of 22 Old 09-18-2009, 06:49 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
87 YJ 4.2L auto 3.73 gears 33" tires. I'm going to stay with 33's it struggles a bit on the highway but its ok. No tach so I dont know the RPM's. I dont have a lot of experience with what it should feel like so I cant compare it to anything. Eventually I'd like to swap in a 700r4. Should I re-gear? How much of an improvement will it make. I drive mostly on road with some off road time 70/30 id say.
Also the speedo is off I'm sure is there a way to get it accuarate?
wanabejeeper is offline
post #2 of 22 Old 09-18-2009, 08:27 AM
flip311
If it mainly on-road or a daily driver I would suggest going ahead and regearing it to 4:10's maybe 4:56's. You will notice a very large difference. I recently had the gears, tranny, and rear axle upgraded and it made such a huge difference in power. You will be really happy with the gears. You can always go with a granny install into your transfer case later if you decide to get into more off-road driving. I own a 88 YJ sitting on 33's.
Colorado Jeep Club member #311
flip311 is offline
post #3 of 22 Old 09-18-2009, 07:56 PM
kirksjeep
I have seen complet axles out of a 4 cyclinder sell on craigslist for $200 -$300 for the pair. The 4 cyclinder axles would give you 4.10 gears cheap. Another option is to find an 8.8 with 4.10 gears and a D30 out of a 4 cyclinder to match, this is what I did.
You can buy a new speedo gear to go in the transfer case to fix your speedometer. You just need to know your gear ratio and your tire size. Check Quadratech or 4wd hardware.
1992 YJ Sahara- 4.5" RE XD, 1" BL, 1" MML, 35" BFG MT, 8.8 w/Aussie, D30 w/Ten Factory shafts/ Aussie, 4:10 gears, Soild Diff Covers, SYE, CV Drive shaft, OBA, Flowmaster Super 44,, Custom head pipe, Super Chip, Boared out TB, Rock It Intake , Goferit Tie Rod Flip, 99+ intake manifold/Steering pump, custom front/rear bumpers,Hand Throttle, Hurst Shifter, Smitty Built sliders , 6" TJ flairs, Kilby belly up skid, Quadratech 9K winch, ZJ PS cooler. 01 XJ Sport-2" lift, 31x10.50 MT/ 02 Liberty 2" Lift
kirksjeep is offline
post #4 of 22 Old 09-18-2009, 08:51 PM
speepdaedeesi
theres a guy by my house that has 4.10 gears from an 8.8 for $75 bucks on craigslist.. if you get your axle lol
89 yj stock- sold
92 yj stock- sold
97 tj 2"bb,31" tires- sold
95 yj soa,350 v8,sm465,44" tires,d60,14bolt- sold
95 yj soa,350v8,700r4,35" tires,d30, 8.8, fuel cell- sold
current ride-97 TJ- 86k miles, 4cyl auto, black casinos, 31" BFG A/T
speepdaedeesi is offline
post #5 of 22 Old 09-18-2009, 09:06 PM Thread Starter
wanabejeeper
1987 YJ Wrangler
Thats a good idea. I started looking and see prices around 200 300 per axle... probably a bit more expensive then I'd like as I would probably have them cleaned and rebuilt. I'll keep it in mind tho and see what I can find. Its always easier if your not in a rush. And since they aint broke yet I'm not.
post #6 of 22 Old 09-18-2009, 10:01 PM
Tubbysworld
1987 YJ Wrangler
check the gearing calculators online. i just installed 4.56s in mine, and i wish id used 4.10s. 37 Nitto mud grapplers and 4.56s make the speedo off the other direction. needed 4.10s to make the speedo right again, now 65mph is around 3000 rpm
Tubbysworld is offline
post #7 of 22 Old 09-18-2009, 10:57 PM
provinT13
I would go this route. Spend the extra $$ now and put in an 8.8 with 4.10's instead of another D-35. It's not even worth unbolting the springs to get that turd under there.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #8 of 22 Old 09-19-2009, 04:56 AM
1998zj
You won't notice much difference between 3.73 and 4.10. I don't think it would be worth the trouble, you are only talking a couple hundred rpm.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #9 of 22 Old 09-19-2009, 06:22 AM
flip311
I noticed a large difference.
1) My jeep rattled crazy in the rear end and for awhile I thought it was my rear tire carrier/ bumper I installed. I even went as far as to weld it to the frame to fix the rattleing sound. The sound finally went away as soon as I read somewhere on this forum that a stock 35 with stock gears sitting on larger tires was known to rattle and decided to switch axles and re-gear. Now my 1988 YJ is rattle free on take off.
2) Goin up hill in 5th gear was a no-go. Any incline caused me to immediatley down shift to fourth. Even in fourth I would slowly lose speed. I could maybe get to 60mph with a head wind. Keeping up with highway traffic was not happening. As soon as the 4:10's were installed I can use 5th gear and my jeep can accelerate past 80mph without blinking.
In short, if it is only a couple of hundred rpm difference then it is the most important couple of hundred rpm in the world. I daily drive mine to work, to pick up the kids from daycare, and to go fishing. I even scheduled to travel from Colorado to Abilene, Texas to pick up my trailer becuase the power difference is that vast for me. My advice is to listen to people here, get quotes for the parts you need and then call some shops and see what their price to regear you stock axles would be. You will see very quickly that the difference in price is extreme and by buying an 8.25 or 8.8 axle with 4:10 already in it you get a stronger more worry free axle and 4:10 gears for half the price of having a store just regear your stock junky axles.
I did my research and decided to go with 4:10's instead of 4:56 or 4:88 because I use my jeep as a DD. Any gearing issues I have out on the trail will eventually be solved by a better transfer case or a gear kit for my np231. Please keep in mind I am no expert and just learning about jeeps but I did spend about a year reading before making any changes to my jeep and when I finally did I was completely satisfied with my decision. Now you need to decide what you think would be best for you and what you plan to do with your jeep down the road. My advice is to regear if you are running 33's but also decide now what you want to do in the future so you don't waste your money later on down the road. If you think it would be fun to start doing trail rides and are not set FOR SURE on staying at 33's then I would definatelly get a different rear axle.
flip311 is offline
post #10 of 22 Old 09-19-2009, 06:29 AM
TSEJEEPERS
I would agree with this. Since you are running a auto transmission you have lower gears than those with manuals.
If you do regear I would go to 4.56, it would put you back in stock range.
flip311 are running a auto or manual transmission?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 22 Old 09-19-2009, 07:30 AM
flip311
This is where my inexperience shows. Manual.
flip311 is offline
post #12 of 22 Old 09-19-2009, 07:38 AM
1998zj
This will give you an idea of the difference in ratios and the rpm's.
Jeep Horizons :: RPM vs Gear Ratio Chart
1998zj is offline
post #13 of 22 Old 09-19-2009, 09:09 AM Thread Starter
wanabejeeper
1987 YJ Wrangler
Guys, really thanks for all the comments. This site is worth its weight in gold. So regear mine or buy the used 8.8 and D30 regear those to 4.56 and install? Is there a specific vehicle I should look for on the 8.8?
post #14 of 22 Old 09-19-2009, 10:38 AM
provinT13
^^ a '95 or higher Ford Explorer.
post #15 of 22 Old 10-02-2009, 04:32 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
95 through 2001 Explorer.
this range gives slip lock diff and disc, and is the best match.
Get a 4.10. Just bought one this week for $250.00.
My issue now is figuring out what is involved with regearing the D30!!!!!!!!!!!!!
hotelconucc93 is offline
Aluminum Radiator - worth the cost??? dbaum77 TJ Wrangler Technical Forum 7 09-23-2009 06:26 PM
Cost of re-gear, #$%^&* Oakiejeep TJ Wrangler Technical Forum 44 07-27-2009 10:40 AM
Re-Gear cost? masedd TJ Wrangler Technical Forum 8 03-03-2009 04:47 PM
short throw shifter worth the cost? fatboyq YJ Wrangler Technical Forum 1 04-27-2006 06:14 PM
Cost of 2005 vs 2004 Rubicon worth it? crsmith TJ Wrangler Technical Forum 6 09-24-2004 09:11 PM
