Re-Gear question - JeepForum.com
post #1 of 6 Old 08-23-2011, 11:30 PM Thread Starter
JeepMeGusta
Re-Gear question
I got stock axles on my 95 sitting on some 33's. I do drive it on the street a lot, but do lots of wheeling as well. I want to re-gear, but I dont know what ratio I should go for. I dont mink going slow(er) on the roads. Oh, and what type should I get? Thanks.
Originally Posted by CopperHead_Road View Post
For repairs I carry the following:Extra fluids, belts and hoses....Oh, and TWINKIES... Lots and Lots of TWINKIES!
CH_R
Originally Posted by jeepyj13 View Post
i have a rc 4" lift so far its pretty leveled, no sags, rides good on hwy, but around town on bumpy roads you swear that your riding a wagon. its a rough ride but oh well ill deal with it.
JeepMeGusta is offline
post #2 of 6 Old 08-23-2011, 11:33 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Looking at your specs on your Jeep 2.5L + Manual tranny = 4.88 gears for 33in. tires
Your milage will increase, You will have stock like power, and your speedo will be accurate, You will be able to keep up with traffic on the hiway ! I ran 4.88's on both of my 4cyl Jeeps with 33" tires. I personally like "Yukon" Brand gears Superior Gear stuff is great also
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 6 Old 08-23-2011, 11:37 PM
kphimself
You may wanna consider upgrading to a ford 8.8 or dana 44 axle on the rear. The stock dana 35 isn't very good if you do any amount of wheeling and it would suck to put all that money into them just to break it on the trail.
kphimself is offline
post #4 of 6 Old 08-23-2011, 11:41 PM
Pullsout
I'm in same boat already bought my 4:88's it gets pricey if you can't do it yourself so best of luck to ya.
Pullsout is offline
post #5 of 6 Old 08-24-2011, 11:10 AM Thread Starter
JeepMeGusta
Do I have to do any modifications with those axles(cutting,welding...) or does it bolt straight on? If I got one of those two, should I still re gear to 4:88's?
CH_R
post #6 of 6 Old 08-24-2011, 11:17 AM
95wrangler4life
The 8.8 does require minor welding (cheap) the Dana 44 will require more fabrication.
Yes, you still need to re-gear. You just dont want to spend money on your crappy rear axle, this will provide you added strength and the gearing will help restore your power.
I had 32's (measured 33's) swampers with my 4.88s for a bit and could cruise 70mph and had 5th gear back, however its rather flat here. got roughly 16-17mpg on a trip from OC-NJ Pines at around 70mph
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
To re-gear or not to re-gear-that is the question goinbroke89 YJ Wrangler Technical Forum 26 01-05-2011 11:40 PM
D30 gear setup question (gear gurus needed) snowrydr01 TJ Wrangler Technical Forum 2 09-15-2010 09:00 AM
...to gear or not to gear! that is the question! BigHit incd JK Wrangler Technical Forum 19 05-31-2007 03:28 PM
Tire/Gear/Speedo Gear question about my 97 TJ SE Black Hole TJ Wrangler Technical Forum 6 05-10-2007 09:20 PM
Reverse Gear question and Tire question RedTJ97 TJ Wrangler Technical Forum 8 06-05-2003 10:13 AM
