RE 4.5 XD Questions - JeepForum.com
post #1 of 7 Old 07-04-2006, 07:50 AM Thread Starter
atomlowe
RE 4.5 XD Questions
Hey people, wondering if you guys could answer a few questions...
1) Has anyone had issues reinstalling their track bar to the axle using the provided reloaction bracket? for some reason, it doesn't line up from side to side by about 1". Also, if the lift is a 4.5" shouldn't the new hole be 4.5" above the original on the bracket?
2) Has anyone else had to replace their ABS Sensor cables? Do most people just disconnect them?
3) How much should this lift settle? I don't think I can get it in my underground parking now...hahaha.
Thanks,
Adam
Canadian Jeep Club Member#8
Jeeps to motorcycles and back to Jeeps again...you just can't get away.
WTD: Hot girls with low morals. Own transportation a plus. Sufferers of yellow fever considered first. PM/email me for details.
atomlowe is offline
post #2 of 7 Old 07-04-2006, 09:25 AM
TellyDSP
Poland and PPV!!!!
My trackbar bracket didnt line up well, and actually bent over time. I'm now using a one form another company that works a lot better, but I dont remember who's it is.
Dont have ABS, so I can't help you there, although I would say disonnect it. I dont know how ABS affects braking off-road, but I can't imagine it being beneficial.
The kit will settle a bit. It'll sit around 4.5-5" once settled. My kit started very high, especially with the soft top on, but with the hardtop, se does sit a bit lower. From the reading I have done, RE measures their kits at the height they sit fully loaded. ie: tops, gear, winch, people. You should be able to fit, it'll probably be close, but my Jeep fits pretty much anywhere. Just watch out for the overhead signs in the garage.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 7 Old 07-04-2006, 12:25 PM
YJtank
trackbar bracket went in like a charm (didn't even need to drill the hole). I am also using the JKS telescoping trackbar so that helps the alignment. The only problem with the bracket is that it got pretty loose even after the first 200 miles despite of the self locking nut. You want to watch out for this...
as far as settling ... well I wouldn't know (the kit is only 3-4 wks old). I'll answer this back to you in six months, i guess.
YJtank is offline
post #4 of 7 Old 07-04-2006, 10:04 PM Thread Starter
atomlowe
I was thinkin about removing the ABS lines. They're quite strained and I don;t see them holding up for even the first time out.
As for the trackbar, I guess its prybar time. I'll get that focker pinned up!
atomlowe is offline
post #5 of 7 Old 07-04-2006, 10:07 PM
YJBlues
YJBlues's Avatar
You should be able to use a floor jack to lift the axle opposit of the direction it needs to go, like if you need it to move left, jack up the right wheel etc. This should make it pretty easy.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #6 of 7 Old 07-04-2006, 10:12 PM Thread Starter
atomlowe
I tried that and the suspension is just too stiff still. I maybe should have disconnect the swaybar though. I used a lift and was able to stack wood under the tire and lower it onto the pile, but no luck. I'll try it again with the swaybar disconnected.
atomlowe is offline
post #7 of 7 Old 07-05-2006, 05:46 AM
TellyDSP
Poland and PPV!!!!
try running without it. I ran into serious bumpsteers without mine, and is the reason I still run it. Others have found they experience no ill effects from not having a front trackbar. Drive it around for a while, carefully, and see how she handles. You will know if you experience bumpsteer.
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
8.8 Questions mideerhunter YJ Wrangler Technical Forum 20 09-10-2008 05:48 PM
CAI Questions KevinR TJ Wrangler Technical Forum 2 08-17-2008 08:41 AM
K&n Questions! mideerhunter YJ Wrangler Technical Forum 1 08-10-2008 09:17 PM
2 lug nut questions- Mickey Mouse kind of questions kaybone TJ Wrangler Technical Forum 2 05-04-2005 04:34 PM
Top questions. Macabre YJ Wrangler Technical Forum 7 06-03-2004 08:19 AM
