RE 2.5" Lift for YJ - JeepForum.com
post #1 of 5 Old 07-10-2001, 12:25 AM Thread Starter
shea324@aol.com
RE 2.5" Lift for YJ
Does anyone have any experience with the RE 2.5" Suspension lift for YJ's? I am considering this for my next project and was wondering if anyone had any input they would like to share. Also if anyone knows of a write-up on this lift online that would be helpful, thanks
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #2 of 5 Old 07-10-2001, 11:15 AM
JPFREEK
JPFREEK's Avatar
I have been running the R.E. 2.5" for about 3.5 years and about 60K miles. I am VERY happy with it, but if I had to do it over again, I think I would have gone with the 4.5" Extreme Duty lift from R.E. The lift rides decent (similar to stock) and flexes great with the sway bars disconnected. I did start to get a little bit of sag in the rear last summer and added Rusty's 3" Add-a-leafs. The AAL's stiffened the ride terribly, but since they have broken in it's back to normal.
-Pete
'91 YJ
JPFREEK is offline
post #3 of 5 Old 07-10-2001, 06:29 PM Thread Starter
shea324@aol.com
Did you have to install a SYE? Also were there any other parts not included in the kit that you had to install? I have heard some good things about the 4.5" Lift but I am only trying to make more room for my 31's - with a 1" shackle lift and 1" body lift they rub under flex.
post #4 of 5 Old 07-10-2001, 11:05 PM
osburn
osburn's Avatar
Pete's advice is sound. You'll only wish you had gotten the 4.5" lift down the road if you don't.
The only time I'd recommend a 2.5" lift is if you know the next step you plan to take is a spring over. 2.5" lift springs make very good SOA springs.
Matt Osburn
Score 1032
osburn is offline
post #5 of 5 Old 07-11-2001, 10:38 AM
JPFREEK
JPFREEK's Avatar
If you are sure you only want the 31's, my suggestion would be to get rid of the shackel lift (my $0.02) and put on a 2.5". I would give some thought to the 4.5" though. With the 2.5" you will not need an SYE, but you will need to drop your T-case. The kit comes VERY complete, the only thing I needed to purchase was a new hard rear brake line, but only because I broke it during the install. With my 2.5" and 1" Body lift, I run 31's, but can clear 32's. I plan to put on some TJ extended flares which will give me enough for 33's and then when I get the 4.5" I will be able to run 35's. I am waiting on the 4.5" because I am trying to come up with the $$$ to buy a D-44 for my rear. Good luck with it.
-Pete
'91 YJ
JPFREEK is offline
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
