rcv axles dana 30 disconnect seals - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > rcv axles dana 30 disconnect seals
JKS Flex Connect in Actions!CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 08-31-2015, 08:18 PM   #1
yjrebuild
Hi
i bought some rcv's and now im leaking by the disconnect.
rcv sells the kit but i was wondering if anyone figured out what they are and if you can get them at napa or something
thanks
yjrebuild is offline   Reply With Quote Quick reply to this message
Unread 08-31-2015, 08:20 PM   #2
yjrebuild
Hi
i bought some rcv's and now im leaking by the disconnect dana 30 (YJ).
im looking for some seals rcv sells the kit but i was wondering if anyone figured out what they are and if you can get them at napa or something
thanks
Unread 08-31-2015, 09:33 PM   #3
bowtech
Junior Member
bowtech's Avatar
Take it apart, remove the seal, get the number from the seal face, and go get one from the parts house. They should be able to cross reference any number that is on the current seal.
bowtech is offline   Reply With Quote Quick reply to this message
Unread 09-01-2015, 10:13 AM   #4
Randonexplosion
Randonexplosion's Avatar
Did you leave everything the same as it was with the 2 piece axle/disconnect setup? You need a seal at the differential, specifically a 11800 from Napa.
5.3/4 link build
Looking for 92+ front female seatbelts
Randonexplosion is offline   Reply With Quote Quick reply to this message
