rci 2161a fuel cell - JeepForum.com
post #1 of 5 Old 10-24-2006, 09:09 PM Thread Starter
5.0YJ
rci 2161a fuel cell
who is runnin this fuel cell in there YJ?? anyone have pics of it hooked up...i just got mine in and it looks like the stock sending unit/pump will fit in there...im gonna cut the hole open to fit it...the cell is 12 inches deep and the sending unit is 11.5...let me know what you guys think of this idea
92 YJ 5.0 AOD NP208 Full width Dana 60/44 axles RE4.5XD SOA lift kit XJ rear stretch comp cut fenders currently on 38" TSLs with hummer double beadlocks and runflats Warn 10,000lb winch Optima battery
WISH I NEVER SOLD IT
97 cHEROKEE SPORT 4DR...BONE STOCK....LOOKING FOR PARTS TO MOD IT
5.0YJ is offline
post #2 of 5 Old 10-25-2006, 12:24 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
search google and follow the pirate4x4.com links... tons of people go that route. only issue you will run into aside from starving for fuel at extreme angles is that the bottom inch of fuel in the tank will be unobtainable.... you will need to extend your fuel pump assembly 1" deeper into the tank..
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 5 Old 10-25-2006, 06:41 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
It's actually only about 1/2" off the bottom. If you divide that up....it's barely a half gallon your not getting. I post pics of mine later today.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #4 of 5 Old 10-25-2006, 07:04 AM Thread Starter
5.0YJ
i actually got it all cut and ready to go...i thought i had read that there was a problem doing this but i guess not...ill get some pics of my setup tonite to as its almost ready to hit the road agian.
5.0YJ is offline
post #5 of 5 Old 10-25-2006, 12:39 PM
Tomb Raider
Addicted...
HELP with fuel line specs to convert to Fuel Cell?? HootenTJ TJ Wrangler Technical Forum 7 04-14-2010 05:58 PM
Anyone with RCI Fuel Cell and PSC TJ Fuel Ring? HootenTJ TJ Wrangler Technical Forum 2 04-03-2007 10:40 AM
What Fuel Pump do I need for RCI Fuel Cell?? HootenTJ TJ Wrangler Technical Forum 4 10-02-2006 03:57 PM
Fuel Cell Scuba Jeepster TJ Wrangler Technical Forum 3 03-13-2006 03:57 PM
Fuel pump - Fuel cell issues MesquiteJeep TJ Wrangler Technical Forum 1 07-19-2005 09:44 PM
