RC lift spring break-in time - JeepForum.com
post #1 of 3 Old 04-24-2002, 10:19 PM Thread Starter
93 Blue Demon YJ
I just installed my Rough Country 3" lift yesterday. After installing it I measured that I gained 4.75". I have heard that the new springs loose about an inch after they break in, and I know my old ones were a little flat, but how long (or far) does it take for them to break in? They are really stiff, and has a real jerky ride. Also, how do they ride once they are broken in? THX
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
post #2 of 3 Old 04-25-2002, 05:30 AM
Atropine
Atropine's Avatar
It usually takes about a month or two, depending on how you drive it. If you off-raod a lot, it takes less time. The ride is really smooth once they are broken in, I love mine.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 3 Old 04-25-2002, 08:01 AM
V8wrangler_idaho
mine are still setteling in it seems. and getting better and better. Just a tip though. Lossen your shakels tell they are just barley tight and then put some lock tight on the bolts to keep them there. that will help out a ton on the ride of the lift. also go and find the roughest and most wash boarded road you can find and drive in it pretty fast for about 45 minuts. and that will just about do it for you. LOL that what I did. amasing diffrence.
Daniel Mclay
93 wrangler 8 inch SOA SRS suspention lift 35/12.50 Mt. efi 350 700r4 tranny np 205 t case dana 44s front and rear. lots of extras.
V8wrangler_idaho is offline
My Spring Break Project 94WorknProgress YJ Wrangler Technical Forum 30 07-11-2012 10:47 AM
new lift break in time?? willyb8 YJ Wrangler Technical Forum 4 07-16-2008 08:39 PM
Spring Break Maintance DemonDeacon TJ Wrangler Technical Forum 2 03-10-2007 08:15 AM
spring break, take top off??? garrett TJ Wrangler Technical Forum 14 03-08-2007 10:45 AM
Spring Break Plans... JeeperAbe TJ Wrangler Technical Forum 3 03-20-2006 05:29 PM
