RC 4" Lift Kit - Page 5 - JeepForum.com
post #61 of 99 Old 07-13-2008, 01:13 PM Thread Starter
tuckinauster
tuckinauster's Avatar
If the leaf springs you have are this design, and you end-up with this as your rear shackle angle (very poor), and the spring clips are clamped down tight like these (very restrictive and prohibit flex greatly), I can't see how these leafs could ever perform nice.
If your leaf spring shackle and leaf are not at an angle of ~90* statically, then they tend to fight each other and cause unwanted suspension dynamics. The greater angle they are from ~90* the worse things tend to be and shackle inversion can come into play be it the front shackles or the rears.
Way too many restrictions and a poor design if you ask me.
Those pics aren't a good representation of the shackle angle, right now they are right around 90* to each other. I think longer, boomer style shackles would remedy that problem. Your right about the spring clamps though, not the best design. I did find that if you pry the clamps open a little it will let the springs move and flex more. For the money, and how I use my rig, these springs perform better than I expected.
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #62 of 99 Old 07-13-2008, 02:15 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
You may even try to open them all the way, drill bolt holes in the clamps, and run a bolt across the upper end. Yeah, this will probably void any warranty and you want to do it using heat if at all possible on the clamps and select a bolt that's not too big nor too small. This way, the clamps will allow much better spring pack movement. It's much easier to do while the leafs are removed & using a drill press, but you get the idea.
When we were testing various leaf clamp designs and engineering leaf packs that we were going to put on the market, we would do this on a regular basis.
I do like the pads between each leaf end.
Joe Dillard is offline
post #63 of 99 Old 07-13-2008, 02:27 PM Thread Starter
tuckinauster
If I had the time/resources to do that, I would look into it. Does anyone sell replacement spring clamps? I'll have to ask Ryan and see how that would affect the warranty.
post #64 of 99 Old 07-13-2008, 04:58 PM
Joe Dillard
I don't build leaf springs for a living anymore, but....I do have a spring shop just a couple miles from where I live. They'd probably sell me some open clamp designed clips if I asked. Or you could ask a local spring maker if you have one, or call a few.
The thing about those clamps and trying to replace them, is that they are often installed using a huck bolt, which is similar to a common pop-rivet. Like these: http://www.rivco.co.uk/huck.html
They are usually not easily removed due to the huck, plus, a huck tool is best when installing a huck, especially in an application like a leaf spring.
post #65 of 99 Old 12-22-2008, 11:16 PM
jerseyrider1119
Is there anything you need the DOESN't come with the kit... brake lines ect..
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
I only read the pictures!
95 Rio Grande- 4" Pro Comp lift, 235x75r15 on stock Alloys, Boomerangs, Piolet Trail Lights, Hurc'd, No Sways or Trac, Custom Under Dash Wiring Harness
jerseyrider1119 is offline
post #66 of 99 Old 12-22-2008, 11:19 PM Thread Starter
tuckinauster
Brake lines don't come with the kit, but you dont necessarly "need" them. Everything else to make it work is included. Even the sweet Rough Country sticker.
post #67 of 99 Old 12-23-2008, 10:02 PM
greenerob
2014 JK Wrangler
How do I loosen the t-case bolts?
Originally Posted by tuckinauster View Post
The t-case drop was really easy. The only tips I have for that is to make sure you loosen the t-case mount bolts so the skid plate is free to slide. An extra set of hands makes it a lot easier to get the holes lined up.
Heres the driveshaft angle. The best part, no vibes at all!!!
Thanks
Rob
1995 Jeep Wrangler Rio Grande 4in RC Lift 33" Tires with 73,000 miles. Auto Trans
greenerob is offline
post #68 of 99 Old 12-23-2008, 10:36 PM Thread Starter
tuckinauster
Use a wrench...
post #69 of 99 Old 12-24-2008, 07:26 AM
greenerob
2014 JK Wrangler
Use a wrench...
Really?
I meant where are they?
Thanks
Rob
post #70 of 99 Old 12-24-2008, 07:33 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Really?
The two bolts sticking down thru the center of the skidplate. The tcase/tranny mount bolts.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #71 of 99 Old 12-29-2008, 07:24 PM
noflacko
noflacko's Avatar
6 total...the skid plate is held up by six bolts. You have to use your floor jack and hold it up there while you put in the pucks (or bar) and longer bolts. Should tighten back up nicely.
Psalm 144:1 "Blessed be the LORD, my rock, Who trains my hands for war, and my fingers for battle..." - SEMPER FI
Cleveland, TN Jeepers UNITE! Monthly meet-N-greet, every third Saturday at Jordan's BBQ!
noflacko is offline
post #72 of 99 Old 12-29-2008, 08:27 PM
durangoyj
You and Rusty are talking about different sets of bolts. I think it is recommended that you loosen the bolts that mount the t-case to the crossmember. Yes there are six bolts to remove when lowering the t-case but it's probably advisable to loosen the bolts actually mounting the t-case to the x-member.
Did I get that right Rusty?
Colorado Jeep Club Member # 176
\m/(..)\m/ "Rock on!"
durangoyj is offline
post #73 of 99 Old 12-29-2008, 08:32 PM
noflacko
noflacko's Avatar
I didn't loosen those...I left it mounted on the upper side of the skid... Should I go back and loosen everything, then tighten it back down?
noflacko is offline
post #74 of 99 Old 05-20-2009, 06:07 AM
bcameron1974
I wanna know this also...
also I gotta tell ya those front lower shock nuts ...omg they suck Ive just started the first one and its pita...gotta get a new blade for the cutoff tool...sucks starting thsi project at 6pm and doin it outside..
bcameron1974 is offline
post #75 of 99 Old 03-28-2010, 03:55 PM
jdgronemeyer1s
I just ordered mine for my YJ, and I plan on doing the install Saturday. So, basically the "tcase drop brakets" are just spacers between the skid plate and the frame? Also, I dont have access to a torch, just air tools. Will it be real tough getting the bolts out?
And great writeup, Im sure it will be very helpful for me when I get going on this.
Thanks
jdgronemeyer1s is offline
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
