RC 4" Lift Kit - Page 3 - JeepForum.com
post #31 of 99 Old 03-23-2008, 11:08 AM
lurkeryj
1997 XJ Cherokee
i just put the rc 4" and set of 32's on my yj, and it rides like a freakin brick. iv put about 200 miles on the street and a day on the trails on them so far. do other peoples ride super rough and how long til they break in and get a little more compliant?
lurkeryj is offline
post #32 of 99 Old 03-23-2008, 11:48 AM
llcustom
I just got my RC 4" lift. I only got three TC drop bolts, am I mising parts or did I miss some info on how to go from six bolts to three.
My Jeep is from New Mexico and feel you pain, I hat to cut out all four spring to frame bolt and both lower rear shock bolts.
llcustom is offline
post #33 of 99 Old 03-23-2008, 11:52 AM
BiTMAP
i would think your missing bolts, because i wouldnt want to go with any less.
BiTMAP is offline
post #34 of 99 Old 03-23-2008, 11:57 AM Thread Starter
tuckinauster
tuckinauster's Avatar
make sure everything is torqued properly and not too tight. i usually run shackle bolts around 50 ft/lbs
Originally Posted by P.J. O'rouke
"The Jeep is a manly device. And a womanly device. An American device. Itís a fitting instrument to transport the free people of a free nation with the respect to which we are entitled and the dignity that we deserve."
tuckinauster is offline
post #35 of 99 Old 03-23-2008, 11:58 AM
sebastian22
i had the same problem when i first put on my lift. the springs soften up over time. it also makes a huge difference if you change your frame bushings, or get greasable shackles.
95 Black YJ
sebastian22 is offline
post #36 of 99 Old 03-23-2008, 01:24 PM
Corpse Kid
i just put the same kit on yesterday but I want to change the shackles. The ones on there are not stock and I have no idea what kind they are. I had to use washers on each side of the spring eyes because the shackles seem to be to wide. What should I switch to? Or what are you using.
Corpse Kid is offline
post #37 of 99 Old 03-23-2008, 01:39 PM
lurkeryj
1997 XJ Cherokee
cool ill give that a shot. i just used my 3/8 impact and tightened them all up. also, i have killer flex in the rear, but i am only using about 3 inches of my shock travel up front. i am running the sway bar up front, could that be limiting my travel that much?
lurkeryj is offline
post #38 of 99 Old 03-23-2008, 01:45 PM
Brads_nky_yj
Go with the MORE shackles. I hear that they are the best you can go with.
Brads_nky_yj is offline
post #39 of 99 Old 03-23-2008, 01:51 PM
sebastian22
A lot of people go with M.O.R.E. I went with Currie because they are 2 blocks from my house, so i didnt have to pay for shipping. Very satisfied.
95 Black YJ
post #40 of 99 Old 04-14-2008, 09:29 PM
njdpb22
did you have to make the driveshaft longer?
njdpb22 is offline
post #41 of 99 Old 04-14-2008, 09:35 PM Thread Starter
tuckinauster
Nope
tenchar
post #42 of 99 Old 04-14-2008, 09:43 PM
njdpb22
tenchar? sorry i dont know what that is
njdpb22 is offline
post #43 of 99 Old 04-14-2008, 09:55 PM Thread Starter
tuckinauster
ya need 10 characters in order to post something, its just a way to make up the characters.
post #44 of 99 Old 04-14-2008, 10:09 PM
YJ_95
Hey i have the same lift with the same tires and wheels. I love the lift.
YJ_95 is offline
post #45 of 99 Old 04-14-2008, 10:14 PM
njdpb22
hahaa oh ok thx. so basicly this lift kit from rough country is a plug and play kit? you dont kneed to do anyother modafications or purchase anythign else to make the kit work?
njdpb22 is offline
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 10:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 03:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 08:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 01:13 AM
