-   -   RC 4" Lift Kit (http://www.jeepforum.com/forum/f12/rc-4-lift-kit-533412/)
tuckinauster 03-15-2008 07:40 PM
RC 4" Lift Kit
Well since Rough Country started using new leaf springs, I decided to give them a shot and ordered up a kit from the RC vendor here on the forum. The kit shipped the same day, and so far customer service has been second to none.
Here's a before picture of my rig. 33's, 1.5" shackles, TJ flares.
http://i197.photobucket.com/albums/a.../2-2-08022.jpg
The rocker height before:
http://i197.photobucket.com/albums/a.../2-2-08024.jpg
The directions said to lift the front first, but there was a '04 corvette in the way so we had to do the rear first. A few days before we installed it, i hit all the bolts with PB blaster a few times. It seemed to help a lot because the all of hardware spun right off, no broken bolts!!
The rear is pretty self explanatory, make sure the frame is securely on jack stands. I took the shocks and track bar off first, and let the axle hang by the springs. Then i took the floor jack and supported axle by the pumpkin. Next i took the shackle off and then the u-bolts.
http://i197.photobucket.com/albums/a.../2-2-08026.jpg
This is what you should end up with.
Next came the fun part :rolleyes:. The bolts that hold the spring to the frame were pretty much welded in after 18 years of never moving. I had to use a MAPP gas torch and burn the bushing out enough to push the spring over so i could cut the bolt. A sawzall blade would just get gummed up with the melted bushing, so I got real good with a cut-off wheel.
http://i197.photobucket.com/albums/a.../2-2-08029.jpg
Once I got the bolt off, and after a quick run to the hardware store to get replacements, the new spring went in without a hitch. After I got everything bolted up I switched sides, It all went smooth except i had to burn out the other spring bushing bolt.
With the new spring installed:
http://i197.photobucket.com/albums/a.../2-2-08028.jpg
After i had both springs in, I lowered the jeep down and put the shocks in and torqued everything. I didnt mess with the track bar brackets, as it won't be spending anymore time under my jeep.
With the rear lifted:
http://i197.photobucket.com/albums/a.../2-2-08030.jpg
After I got the jeep moved back enough so the vette wasn't in the way we started on the front. The first thing we did was pull the pitman arm. With a little heat and some persuasion from a BFH, it popped right off. Next the swaybar and track bar came off, followed by the front shocks. After everything was disconnected, it was pretty much the same deal as the rear. Of course the front spring bushings both had to be burned out and cut off.
Again the PB blaster treatments seemed to work great, as everything came off really smooth.
Disconnecting the front:
http://i197.photobucket.com/albums/a.../2-2-08034.jpg
Front lifted:
http://i197.photobucket.com/albums/a.../2-2-08048.jpg
The t-case drop was really easy. The only tips I have for that is to make sure you loosen the t-case mount bolts so the skid plate is free to slide. An extra set of hands makes it a lot easier to get the holes lined up.
Heres the driveshaft angle. The best part, no vibes at all!!!
http://i197.photobucket.com/albums/a.../2-2-08049.jpg
All in all, with the running around we did, the lift took about 8 hours to finish. So far I'm very happy with how it turned out. It rides a little stiff, but its getting better as the springs break in. The only concern i had was the left rear spring started to break in sooner and it gave the jeep what was described to me as a "shoulder lean." I called RC about it and they said that it would go away once the springs are finished breaking in. In the last couple days it has started to level out. Here are some pics of it all finished, and a few flexing on the snowbanks at work. I'm sure I've forgot some stuff, so if you have any questions, comments or suggestions please let me know.
More Pics:
http://i197.photobucket.com/albums/a.../2-2-08063.jpg
http://i197.photobucket.com/albums/a.../2-2-08061.jpg
http://i197.photobucket.com/albums/a.../2-2-08060.jpg
http://i197.photobucket.com/albums/a.../2-2-08059.jpg
http://i197.photobucket.com/albums/a.../2-2-08058.jpg
http://i197.photobucket.com/albums/a.../2-2-08064.jpg
http://i197.photobucket.com/albums/a.../2-2-08065.jpg
bigredcherokee 03-15-2008 07:49 PM
Nice job! looks good.
millersjeeps 03-15-2008 09:05 PM
looks good. ive been thinking about getting the same lift for my 95. let me know how the new springs RC is using feel in a couple months.
tuckinauster 03-15-2008 09:11 PM
i'll keep this thread updated as the springs finish breaking in. so far they are working in nicely.
thegrimlinyj 03-15-2008 09:49 PM
Why does your wrangler have round head lights?
rustywrangler 03-15-2008 09:56 PM
You suck you know that, LOL.
Now go get yourself a face shield before you take shrapnal in the eye :cheers2:
Looks good man.
-Rusty :tea:
Barrio 03-15-2008 10:11 PM
looks real good bro, i cant wait till spring to start mine!!
tuckinauster 03-15-2008 11:36 PM
factory option :rolleyes:
tuckinauster 03-15-2008 11:39 PM
Looks good man.
-Rusty :tea:
:laugh: thats not the first time i've heard that. don't you have a BDS lift on the way?
yjsupporter 03-16-2008 12:01 AM
nice thread
Opihi59 03-16-2008 12:47 AM
Thanks for the write-up, nice touch with the photos of the before and after "tale of the tape." As things settle in, let us know how the measurements end up. I may very well be putting this same lift on my 93 later on this spring what with your photos and all the encouraging words from the RC representative, but since I run 31's to your 33's, it may be a bit too much lift. On your project, you went back to standard shackles and got rid of the 1.5" lift shackles, right? Thanks, and good work.
rustywrangler 03-16-2008 12:54 AM
Hey now that's not very nice to..... Well, yea, what's it to ya??
:D:D:D:D:D
vfrpilot 03-16-2008 06:43 AM
3 Attachment(s)
Originally Posted by Opihi59 (Post 4955707)
since I run 31's to your 33's, it may be a bit too much lift. ......
With 31's [I]
http://i161.photobucket.com/albums/t...0220081729.jpg
tuckinauster 03-16-2008 10:01 AM
:D:D:D:D:D
:laugh: I guess that means I'll keep my eyes open for your lift thread. Hopefully it'll include some action shots, if you have your jeep put back together enough that is ;)
The time now is 04:45 AM.
