rattling from tranny/tcase - JeepForum.com
post #1 of 5 Old 04-06-2013, 07:46 PM Thread Starter
lanny94
i have a 1990 jeep yj with the 4.2, ax15, and np231. the tranny was taken apart last week from a fairly reputable jeep shop and they inspected it and where essentially left scratching there heads. about a year ago i put the sye in on my tcase. thats my background info if anything else is needed let me know.
so for the past month my tranny/.tcase has been making very sketchy/worry sounds the best way to describe it is that a piece a metal is flying around it only happens once i get into 3rd gear and the higher the gear the worse it gets/more i press the pedal down.
i have also replaved 4x4 shifter and all new piping/muffler in the past week
hopefully that works
lanny94 is offline
post #2 of 5 Old 04-07-2013, 10:50 AM Thread Starter
lanny94
Any one?
lanny94 is offline
post #3 of 5 Old 04-07-2013, 11:07 AM
bigbossd1030
As in the clutch pedal?
Have you replaced the throwout bearing?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 5 Old 04-07-2013, 05:01 PM
bigsquat
i was getting some noise out of my zj transfercase and it was the chain. i dont think pushing in the clutch changed the noise tho , so it might be something else. ive never had a bad throw out bearing so i dont know the symtems of that. see if the tc oil has a lot of metal in it like my zj did.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #5 of 5 Old 04-07-2013, 05:07 PM
bigbossd1030
The throwout bearing will cause a terrible noise when the clutch pedal a pressed. It's hard to describe, but it will make your heart drop to your balls when you hear it. It's kinda a grindingish noise.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
