raptor liner question - JeepForum.com
post #1 of 5 Old 01-20-2012, 07:03 AM Thread Starter
saintk99
going to spray the tub today. the directions say to clean the gun that came with the kit between sprays. What should i use to clean the gun?
saintk99 is offline
post #2 of 5 Old 01-20-2012, 07:04 AM
tdewit
IMO, no need to clean the gun. I sprayed 4 bottles without once cleaning. It has a working time of about 1 hour before drying.
tdewit is offline
post #3 of 5 Old 01-20-2012, 07:08 AM Thread Starter
saintk99
also says between 40 and 70psi....thats kinda a big variance. what did you use?
saintk99 is offline
post #4 of 5 Old 01-20-2012, 07:20 AM
tdewit
I used 50psi at the nozzle
tdewit is offline
post #5 of 5 Old 01-20-2012, 06:32 PM
hesserdude07
it all depends on how u want it to look... the lower the PSI the smoother it will look. The higher the more 'grit' it will have. You can also adjust how close or far u hold your gun from the tub. hope it helps
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
So torn...Husky Liner or Rugged Ridge Liner? boltsnnuts JK Wrangler Technical Forum 28 08-14-2009 10:36 AM
Bed liner Gun question Godchsr Wrangler General Discussion 8 05-03-2009 09:33 PM
Bed liner question... melius Wrangler General Discussion 3 04-05-2009 11:37 PM
Another Liner question XJtheTanK YJ Wrangler Technical Forum 4 09-10-2006 02:32 PM
bed liner question Bob J TJ Wrangler Technical Forum 5 06-16-2003 01:53 PM
