ran out of gas, now jeep wont start - JeepForum.com
post #1 of 8 Old 06-23-2011, 11:28 PM Thread Starter
InEmberClad
so I had left the jeep with a mechanic buddy of mine to replace the clutch, he gives it back to me running on fumes which is fine, there's a gas station up the street. Jeep dies as I pull up to the pump and I'm thinking "wow how lucky"
... fill her up and now it won't start at all. Pretty much like there's no fuel in it.
thoughts?
InEmberClad is offline
post #2 of 8 Old 06-23-2011, 11:34 PM
austentatious
Need more info. Whats it doing when you try to turn it on? Is it turning over? Or is there nothing happening at all? Any specific noises?
O|||||||O
|ProComp|Rokmen|Zone|MetalCloak|RockHard|Mastercra ft|TomWoods|Novak|TenFactory|Synergy|
austentatious is offline
post #3 of 8 Old 06-23-2011, 11:45 PM Thread Starter
InEmberClad
starter still cranks, fuel pump still primes, it just won't fire.
post #4 of 8 Old 06-23-2011, 11:49 PM
austentatious
I would check your spark and then go from there
O|||||||O
post #5 of 8 Old 06-23-2011, 11:52 PM
COLOUXJ
2010 JK Wrangler
I would also check your fuel filter, all kinds of debris can get in it if you run out of gas, especially on older model vehicles.
COLOUXJ is offline
post #6 of 8 Old 06-24-2011, 12:31 AM
azfyrmedic
Might want to be sure that the fuel is getting to the rail.
I have been working on a simular problem today. turns out I was not getting fuel to the rail untill I jumped the wire to the pump and ran it until I could get the fuel to the quick connect at the fuel rail.
azfyrmedic is offline
post #7 of 8 Old 06-24-2011, 07:31 AM
nembudonna
X2 You get a lot of trash at the bottom of the tank. Going through the same thing now. Best to keep at least a 1/4 of a tank in there.
nembudonna is offline
post #8 of 8 Old 06-24-2011, 08:24 AM
grandboost98
not only will you suck up all the gunk at the bottom of the tank but i heard our fuel pumps are cooled by the gas so you have a better chance of burning out the pump if you run your tank close to E alot
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
jeep wont stay running, now wont start 89General YJ Wrangler Technical Forum 5 02-11-2011 05:57 AM
Jeep wont start- no CEL abadjay YJ Wrangler Technical Forum 5 10-24-2008 06:23 AM
Jeep wont start advice on where to start? vangosu TJ Wrangler Technical Forum 6 08-25-2008 08:28 AM
jeep wont start CRAZYJ1988 YJ Wrangler Technical Forum 6 02-17-2006 01:12 PM
Jeep Wont Start Brindle19 YJ Wrangler Technical Forum 1 12-28-2005 05:22 PM
