Raising with additional leaf springs - JeepForum.com
 4Likes
post #1 of 23 Old 05-30-2017, 07:57 PM Thread Starter
Leckbass
I'd like to remove the long shackles in the front and back of my jeep, but I'm afraid that the tires will rub. I'd like to make up the 1 inch.
Can I add a leaf under the current springs that will take up sone space and help with some of the sag?
Leckbass is offline
post #2 of 23 Old 05-30-2017, 08:28 PM
puppybreath
Can add a leaf, but to me those springs look like they are nearing the replacement stage anyway, may be cheaper/more effective in the long run to do a lift.
bruinjeeper likes this.
puppybreath is online now
post #3 of 23 Old 05-30-2017, 08:32 PM Thread Starter
Leckbass
I believe it already had a 4 in lift, so would I just need to order springs?
Leckbass is offline
post #4 of 23 Old 05-30-2017, 09:00 PM
bruinjeeper
Yes.
Those are severely sagged and tired. I 2nd puppybreath's suggestion...
just piecemeal out a good lift (try and avoid kits as they include crap you don't need for $$$). Are you on a tight budget? I mean, a new and very functional pieced together lift (including shackles if you wanted them replaced) can be had on a budget without advice.
WHat are you looking for? stance? performance? comfort?
Your profile is still not filled out ....from your other pics it looked like you had 35" pizza cutter tires (am i right?)
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is offline
post #5 of 23 Old 05-30-2017, 09:16 PM
Chrisnvegas
Chrisnvegas's Avatar
Yeah, those springs look wheezed.
But I bet an add-a-leaf would probly get the inch you want too.
I wouldn't attempt to re-use those u-bolts though.
They have a good bit of corrosion and I wouldn't trust them with my life after being loosened.
Me thinks an assessment is in order.
find out where you are now, and evaluate where you wanna go before tearing into it.
How big are your shackles? Measure bolt center to bolt center.
How much lift do you have now?
Measure from the ground to your rockers. Subtract additional height from shackles over 4" (anything over 4" divide by 2, that's your shackle lift.)
Tires were originally @ 27" tall.
Off road package has gas shocks and 225/70/15 (27.4")
Regular has 215/70/15 (26.85")
Any body lift?
If not, an inch can be gained there for fender clearance.
Figure out where you are, where you're going, the best way to get there for your needs.
Ban computer updates and autoplay video! Boycott music without real instruments and singers using autotune.
Chrisnvegas is offline
post #6 of 23 Old 05-31-2017, 04:12 AM Thread Starter
Leckbass
Right now, the rockers are 25 in off the ground.
The tires ar 34s = 3" lift
Shackles 6.5in center to center = 1"
Springs = 3"
Total 7" lift
I'd like to stay at that same height, but I want to shorten the shackles or go to stock shackles.
Down the road, I'm planning on buying 33 in A/T tires and selling the super swampers.
I'm not for or against a body lift, but I think my spare tire rack will prevent a body lift.
Trying to keep it simple.
Leckbass is offline
post #7 of 23 Old 05-31-2017, 04:16 AM Thread Starter
Leckbass
Please advise on this, I'm open to suggestions. I'll gladly use a kit that includes the leaf, the shackle, and shocks.
Leckbass is offline
post #8 of 23 Old 05-31-2017, 01:47 PM Thread Starter
Leckbass
All the lift kits I see are in the $500 range and include much more than I need, I can't seem to find the lift kit with just the springs and shackles
Leckbass is offline
post #9 of 23 Old 05-31-2017, 02:47 PM
Chrisnvegas
@Leckbass
Here's an example.
Zone 4" springs which includes bushings.
They have options below.
You can add u-bolts, shims ect, only what you need.
http://www.ebay.com/itm/1987-1995-Je...-/172259056439
Then look around for shackles.
These are zero lift shackles.
http://www.ebay.com/itm/1987-96-Jeep...NYkjg-&vxp=mtr
Just some examples. I don't know if the springs or shackles are any good.
I've never heard anyone complain about Zone or BDS springs.
paulhead likes this.
post #10 of 23 Old 05-31-2017, 08:00 PM Thread Starter
Leckbass
I appreciate your help. I guess what I'm looking at is a little bit over $400. I'm going to keep my eyes open to see what else is out there.
Leckbass is offline
post #11 of 23 Old 06-01-2017, 09:11 PM
RockWoRM
RockWoRM's Avatar
You can also buy springs only from BDS... but they are a good quality spring and may be more $$... but you get what you pay for. I had 5" BDS's and they were great. Those + 1" BL and they cleared 35's w/no cutting involved.
Back to your original Q... yes you can add a leaf to any spring pack, but if you do not know what rate the leaf is it is a best guess scenario. I have nothing against bastard packs, as they can work well, but again, you have to know what you're working with or simply get lucky if they work out.
Back in the day... places like Rancho and RE sold add leafs for extra lift. About all they did was make the whole set up ride like a tank!
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #12 of 23 Old 06-02-2017, 11:43 AM Thread Starter
Leckbass
What about a 1in block under the spring?
Leckbass is offline
post #13 of 23 Old 06-02-2017, 11:49 AM Thread Starter
Leckbass
Looking to spend a lot less...
Leckbass is offline
post #14 of 23 Old 06-02-2017, 12:16 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
That would lower you by 1".
93YJfalcon likes this.
Randonexplosion is offline
post #15 of 23 Old 06-02-2017, 06:17 PM Thread Starter
Leckbass
How would it lower it?
Leckbass is offline
