Rain puddle on soft top?? - JeepForum.com
post #1 of 21 Old 05-27-2013, 02:40 PM Thread Starter
flcracker
I have a new top on my '92 and when it rains, I get a pretty good size puddle between the bar and the windshield. Is there any type of bow or support that anyone makes to support the fabric there to prevent this?? It seems like it is stretching out the fabric and making it looser than it needs to be compounding the problem each time it rains....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #2 of 21 Old 05-27-2013, 02:53 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Quadratec sells a bow to push up the top. You may need some adjustable tension rods for the top
Sent from iPhoneusing JeepForum
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 21 Old 05-27-2013, 03:07 PM Thread Starter
flcracker
Thanks, I knew I saw this somewhere before but I couldn't remember where. Anyone else using this thing??
post #4 of 21 Old 05-27-2013, 03:08 PM
Tom95YJ
Tom95YJ's Avatar
I used them on my bikini and duster on my 95
'99 XJ Black Betty
Tom95YJ is offline
post #5 of 21 Old 05-27-2013, 03:44 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
There are a lot of people using this. If you're feeling handy, go to lowes and get some PVC pipe, I think people use 1/2" (suppose you can check the bendyness while you're there) and appropriate T fittings(X2) and you can make your own by cutting the top of the T in half that creates a cup which fits around your roll bar/padding. You can use an X piece too and cut it in half. Then you just cut the pipe to the length that will give you the bow you'd like and push it together. Easy and quick.
Michaelgoesrawr is offline
post #6 of 21 Old 05-27-2013, 03:44 PM
jbolty
jbolty's Avatar
1/2 pvc
tee on top
cut long enough to reach from floor or console to hold up top
profit
jbolty is offline
post #7 of 21 Old 05-28-2013, 06:51 PM
jserna
1987 YJ Wrangler
I used the fiber glass rods from a on old dome tent.
jserna is offline
post #8 of 21 Old 05-28-2013, 07:01 PM
MJDriver
MJDriver's Avatar
I did the floor to roof thing with a mop with a flat 6" x 12" head. Spreads out the push on the top and works well.
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline
post #9 of 21 Old 05-28-2013, 11:34 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Only in a YJ.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #10 of 21 Old 05-29-2013, 08:31 AM
EABiker
As an added bonus, you can use the mop to cleanup the rainwater that leaks through the dash and collects on the floor!
I, myself, use the lower portion of my old deck umbrella to keep my bikini top from giving me a cold shower after it rains.
EABiker is offline
post #11 of 21 Old 05-29-2013, 09:43 AM
babasnoopy
I have the Skid Row Top Prop. Works great. It fits nicely behind the front seats when I take the bikini off as well.
babasnoopy is offline
post #12 of 21 Old 05-29-2013, 05:30 PM
pasinbuy
Find a flat piece of aluminum two inches wide about three feet long. Can be purchased at your hardware store.
Cut a notch on one end to fit into the bimini strap holder on top of your windshield, dead center.
Bend the aluminum to bow it a little, about as much as a regular bow that shoots arrows. Stick the notched end of the flat aluminum into the bimini strap holder, lay the other end over your roll bar.
Now no more puddles on your top.
pasinbuy is offline
post #13 of 21 Old 05-29-2013, 05:41 PM
Luuca
Luuca's Avatar
NOPE. Gotta use a MOP.
YJOTM Sept. 2017
Luuca is offline
post #14 of 21 Old 05-29-2013, 07:18 PM
SuperMidget
My solution... 2"x48" I think was the length... 90 degree bend and attach to windshield... I was lazy and shot a screw in em instead of drilling a hole and putting on behind a screw for the visor .. push tension to where you want it then bend around the roll bar and problem solved
SuperMidget is offline
post #15 of 21 Old 05-29-2013, 10:06 PM
MJDriver
MJDriver's Avatar
Nicely done.
MJDriver is offline
