Radio wiring, 90 YJ - Page 2 - JeepForum.com
post #16 of 18 Old 05-13-2013, 12:49 PM
Rproject
1987 YJ Wrangler
Does this help?
GRN w/ TR - Left Rear Feed
GRN - Left Front Feed
BLK w/ TR - Left Front Return
BRN w/ TR - Left Rear Return
WHT w/ TR - Right Rear Feed
WHT - Right Front Feed
BLK - Right Front Return
BRN - Right Rear Return
BLK - Ground
VIO - Ignition controlled power
ORN - Panel Intensity Input
Anybody notice what's missing? Yup, a constant power source. If your YJ is like mine, and has an analog clock in your gauge cluster, you have NO constant power source at the radio. I had to tap a new line from the battery to get my new radio working.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #17 of 18 Old 05-13-2013, 03:11 PM
1celtmom
thanks
Thanks for the suggestions. I checked all the fuses and they look fine, I'll see if my son can help with checking the voltage. I appreciate all the help!
1celtmom is offline
post #18 of 18 Old 04-03-2016, 08:46 PM
dhernsky
1990 YJ Speaker Wiring
Originally Posted by johnoutdoors View Post
The only wires on my 1990 YJ harness that matched any of the schematics I have researched is the Pink (constant 12V), Black (ground) and Violet (switched 12 V). None of the other wire colors match so I'm just going to install new speakers and wiring and be done with it.
1990 YJ
4.2L w/Howell TBI conversion
Hankook ATM 31x10.50x15
5 spd. manual tranny
dhernsky is offline
Radio Wiring Garpo YJ Wrangler Technical Forum 4 01-09-2007 08:48 PM
Is Radio wiring present if jeep originally came without a radio gary1 YJ Wrangler Technical Forum 14 02-07-2006 09:10 PM
Radio wiring UltimatE YJ Wrangler Technical Forum 1 03-05-2005 10:33 PM
92 YJ Radio wiring Shinner YJ Wrangler Technical Forum 0 09-23-2003 05:37 PM
Radio Wiring help!! ohhpe YJ Wrangler Technical Forum 6 07-03-2003 10:42 AM
