Radio problem - JeepForum.com
post #1 of 14 Old 08-25-2011, 11:57 PM Thread Starter
Xpress
Radio problem
Was driving on the freeway and all was well, but as soon as I got off and came to a stop, the radio started to go loopy. It would fade in and out and then the signal went away completely in an area where I have never had signal issues.
It has been doing it all day long. I stopped in a spot where it had a good signal, so I went inside and poked around, didn't see anything loose or shorting or whatever. The weird part is when I touched the antenna, the signal faded away to about half of what it was. Not the cable, the antenna itself. What could it be?
I noticed about a week ago, when I was decelerating to a stop that it made a whirring noise in conjunction with the engine RPM's, but it never did that again.
All about that unibody life.
Xpress is offline
post #2 of 14 Old 08-26-2011, 12:11 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Sounds like a ground problem.
Luck Favours The Prepared
Anticanman is offline
post #3 of 14 Old 08-26-2011, 12:22 AM Thread Starter
Xpress
JFIRC suggested the ground cables, but both are tight as can be. The ground cable on the radio is also tight and good.
Xpress is offline
post #4 of 14 Old 08-26-2011, 12:40 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Maybe the antenna cable isn't fitting correctly or the head unit just isn't working correctly. Have you tried a different head unit just to test it? Maybe adding a temporary ground to the unit itself? It's a pretty tedious process when you chase electrical gremlins, especially when they're not consistent. Keep trying to eliminate possibilities by using alternate sources.
post #5 of 14 Old 08-26-2011, 07:05 AM
Que89YJ
Electrical issues come down to power and ground. Do you have a meter to run a couple test? Harbor Freight has one for under $10.
Que89YJ is offline
post #6 of 14 Old 08-26-2011, 07:33 AM
Andywear
A radio in a jeep, dont those get stollen?
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #7 of 14 Old 08-26-2011, 12:40 PM Thread Starter
Xpress
Not everyone lives in the ghetto.
Nope, and not even the $ buy one right now
Xpress is offline
post #8 of 14 Old 08-26-2011, 12:48 PM
Andywear
B/C your saving for an engine swap?
Andywear is offline
post #9 of 14 Old 08-26-2011, 01:01 PM Thread Starter
Xpress
Don't you have other people to go bug? Contribute to the thread or leave.
Xpress is offline
post #10 of 14 Old 08-26-2011, 01:16 PM
Andywear
Hey! Theres nothing left to add. Ground/connections or radio.
Thread is now open for whoring.
Andywear is offline
post #11 of 14 Old 08-26-2011, 01:22 PM
Que89YJ
If you touch the mast you are untuning it. It is setup to be a quater wave length in the fm and the am band get really confusing so I'll let that one go for a later day. If the signal was fading on more than one station then I would beleive you had a radio problem but I need your input. Radio stations have all sorts of quirks depending on the band and location and I need to know if it was happening on more then one station? Was in both AM and FM? and far apart were the locations it happened at?
Que89YJ is offline
post #12 of 14 Old 08-26-2011, 02:13 PM Thread Starter
Xpress
I figured it out. Somehow when my brother was changing stations when we were on the freeway, he bumped one of the buttons on it, says LOCAL on the button, so I assume it's for dumbing down strong signals or something. So that explains why it began to fade out in the rural areas I guess, now it's back to normal.
And fwiw, yes it did that on every station.
Xpress is offline
post #13 of 14 Old 08-26-2011, 02:32 PM
Que89YJ
It changes the bandwidth around the tuned frequency to give it better signal to noise ratio but less signal strength. LOL keep him away from your power tools.....god knows what he would bump and do then!
Que89YJ is offline
post #14 of 14 Old 08-26-2011, 03:11 PM Thread Starter
Xpress
LOL come to think of it, he's been hacking away at a project today...
Xpress is offline
JK Radio problem beel JK Wrangler Technical Forum 18 01-04-2011 01:02 AM
Radio Problem? tigers34 JK Wrangler Technical Forum 6 09-11-2008 05:47 AM
92 YJ Radio Problem Jeepers28 YJ Wrangler Technical Forum 9 06-25-2008 08:26 PM
Radio Problem tbrkek JK Wrangler Technical Forum 0 01-26-2007 07:23 PM
03 wrangler radio problem laddie TJ Wrangler Technical Forum 9 01-01-2006 09:10 PM
