Radio issues - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Radio issues
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-31-2013, 04:07 PM   #16
tcook95beast
Ok is there a diagram I can follow to make sure that everything is wired correctly?
tcook95beast is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 04:13 PM   #17
Rproject
1987 YJ Wrangler
From the original, factory, wires, here's what you should have:
Radio 12v pink +
Radio Ground black -
Radio Ignition red +
Radio Illumination orange (dimmer) +
LF Speaker +/- dk. green - brown/red +,-
RF Speaker +/- purple - dk. blue/red +,-
LR Speaker +/- brown/yellow - brown/lt. blue +,-
RR Speaker +/- dk blue/orange - dk blue/white +,-
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 04:18 PM   #18
tcook95beast
Can't see the pics...can u send them again?
Unread 07-31-2013, 04:22 PM   #19
Rproject
1987 YJ Wrangler
I redid it as text. It should be:
Radio 12v pink +
1996 White ZJ
Unread 07-31-2013, 08:50 PM   #20
Rproject
1987 YJ Wrangler
Incidentally, how did you get the radio out without the keys?
1996 White ZJ
Unread 07-31-2013, 09:07 PM   #21
tcook95beast
I used butter knives, needle nose pliers, and a soft touch. Lol! Wasn't too difficult.
Unread 07-31-2013, 09:15 PM   #22
Rproject
1987 YJ Wrangler
Well played.
1996 White ZJ
Unread 07-31-2013, 09:26 PM   #23
tcook95beast
Haha thanks. Almost got all the connections fixed, got too dark to see.
Unread 08-01-2013, 08:02 AM   #24
tcook95beast
Well I have done away with all the electrical tape and installed all the crimp on butt connectors to the connections. Connections seem to to be going to the right places. I reconnected the battery and the stereo has power and all the functions work, but I have no sound...
WTF?
Unread 08-01-2013, 08:09 AM   #25
Rproject
1987 YJ Wrangler
Have you checked the fuses on the back of the stereo?
1996 White ZJ
Unread 08-01-2013, 08:16 AM   #26
vcallen7
Might need to check the wiring all the way to the speakers too for more taped connections
vcallen7 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2013, 09:58 AM   #27
tcook95beast
If there was one bad connection would it cause all of the speakers not to work...
I checked the single fuse on the back on the stereo and it is ok
Unread 08-01-2013, 10:03 AM   #28
Rproject
1987 YJ Wrangler
Not likely. Can we assume you did a 1-for-1 wire replacement? Or did you cut everything and redo everything from scratch?
I know it's not likely, bit I have to ask ---- you did put the plug on the back of the radio back in the proper direction, yes?
1996 White ZJ
Unread 08-01-2013, 02:00 PM   #29
tcook95beast
I did a 1 to 1 transfer. All of sudden it started to work.... Something must be shorting out somewhere along the wires themselves.
Unread 08-01-2013, 02:08 PM   #30
Rproject
1987 YJ Wrangler
Check your ground. Make sure it's a true body ground.
1996 White ZJ
