radio install question - Page 2 - JeepForum.com
post #16 of 25 Old 04-11-2007, 04:38 PM Thread Starter
joe's_yj
joe's_yj's Avatar
Originally Posted by Rescuer
THis is going to sound bad but, did you disconnect the batt to start the work by chance and not reconnect it?
IVE DONE IT!!!!
You have double checked the fuses?
Do you even get a clock?
Did you try with the keys in?
yes the battery connect is hooked up, i dont know what fuse to check, i dont get a clock and i have done it with the keys in and started. Thanks
joe's_yj is offline
post #17 of 25 Old 04-11-2007, 05:37 PM
trickle26
trickle26's Avatar
so did the new radio you are trying to install come with a seperate harness to connect to the factory wiring or did you crimp each individual wire from the new radio to the factory wires? Double check your colors on the corresponding wires for Power lead, remote, make sure the ground is tight, speaker wires etc.? Make sure the harness and or crimps are all solid and tight.
Some radios come with an inline fuse as someone mentioned earlier also check the fuse in your fuse panel on the inside firewall. It may have blown when the other radio was stolen, wires got crossed or yanked around, etc.
97' ZJ Limited V8 - 5.2 liter
94' YJ 4.0 ho -SE -
past jeeps: 89' YJ
87' YJ Laredo
88' YJ Sahara
90' XJ Limited
trickle26 is offline
post #18 of 25 Old 04-11-2007, 05:40 PM Thread Starter
joe's_yj
joe's_yj's Avatar
i was thinking its the fuse i just dont know what one to check
joe's_yj is offline
post #19 of 25 Old 04-11-2007, 06:11 PM
Semperfi
starting from the bottom left of the fuse panel go up one... according to my online pub it powers the cig lighter, radio, and illumination lamps. i don't have my yj with me but pm me if i can be of further assistance...
good luck
"Once a Marine...Always a Marine"
Semperfi is offline
post #20 of 25 Old 04-11-2007, 07:32 PM Thread Starter
joe's_yj
joe's_yj's Avatar
thanks alot, i really appericate it guys. Ill check that fuse out tomarrow
joe's_yj is offline
post #21 of 25 Old 04-12-2007, 12:16 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
get a multimeter..... lowe's sells a greenlee for $18 that'll be perfect for everything jeep related and it's even got a crappy rubber "boot" to help protect it from damage when you drop it....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #22 of 25 Old 04-12-2007, 09:54 AM
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
A lot of the time there is an inline fuse. It is in a semi clear/white sleve. It holds a fuse that is skinny and round in size. You twist the clear/white sleve to open it. You should be able to check the fuse with ease to see if it is blown. I'm 99% sure you have a fuse problem
TrailWorthyFab is offline
post #23 of 25 Old 04-12-2007, 10:02 AM
gary1
gary1's Avatar
If you are installing a stock OEM Radio, the wire you show plugs onto a tab that is already on the back of your radio.. It is right beside the main plug-in...
The wire is already attached to a ground, and its purpose is to ground your radio. If the tab is missing, just loosen a screw on your new radio and attach the wire to it, which will ground the radio...
To acquire knowledge, one must study; but to acquire wisdom, one must observe.
gary1 is offline
post #24 of 25 Old 04-12-2007, 10:15 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Wait a min. The wire in your pic ( as asked above) comes from the truck not the radio? If so then with above, just attach it to one of the screws on the radio.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #25 of 25 Old 04-12-2007, 12:15 PM
TrailWorthyFab
TrailWorthyFab.com
pm me your email and I will send you a complet wireing diagram for your jeep. This was a huge help when I coudn't get my 4wd light to come on. It tells you (as far as the jeep goes not your radio) what every color of every wire in your jeep is and what it goes to/from. Great tool when trying to figure out where you weak link is.
new radio install - distributor noise on Radio bestos YJ Wrangler Technical Forum 8 10-03-2009 09:47 PM
Guages and Radio doesn't work after radio install HoosierDaddyTJ TJ Wrangler Technical Forum 3 04-15-2009 02:57 AM
Radio Fuse /radio not working of after fog light install? Bonesboy JK Wrangler Technical Forum 0 03-17-2009 04:38 PM
Cb Radio Install oompaloompasc3 YJ Wrangler Technical Forum 15 07-23-2008 11:44 AM
95 yj Radio install ou812 YJ Wrangler Technical Forum 17 10-26-2005 11:08 PM
