radio install question - JeepForum.com
post #1 of 25 Old 04-10-2007, 05:25 PM Thread Starter
joe's_yj
joe's_yj's Avatar
okay so iw ent to install my raido, my previous one was stolen when the po had it. I have this balck wire and i cant figure out what it is or where it goes, if someone could please help me that would be great. Thanks
joe's_yj is offline
post #2 of 25 Old 04-10-2007, 05:26 PM
jeepnmike
jeepnmike's Avatar
possibly the ground?? Its been a while since I put my headunit it so I could be wrong...
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
post #3 of 25 Old 04-10-2007, 06:03 PM
pointech
2014 JK Wrangler
I think it is the ground. There is no ground in the harness, it is a separate black wire (so I have been told).
Tom in Virginia
pointech is offline
post #4 of 25 Old 04-10-2007, 06:13 PM Thread Starter
joe's_yj
joe's_yj's Avatar
would that be a reson why my radio isnt working?
joe's_yj is offline
post #5 of 25 Old 04-10-2007, 06:15 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Yes, if your radio is not grounded it will not work at all.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #6 of 25 Old 04-10-2007, 06:31 PM Thread Starter
joe's_yj
joe's_yj's Avatar
alright, but that one doesnt have a screw mount anywhere on the connector. Where would it usually be connected?
joe's_yj is offline
post #7 of 25 Old 04-10-2007, 06:49 PM
rustywrangler
On mine it is part of the harness but its also an 89. If you are putting in a new radio check to see if the ground is in the harness. may just want to post a pic of the back of the radio
post #8 of 25 Old 04-10-2007, 07:23 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
the black wire on your new radio harness has to be grounded... whether that happens through your oem wiring or you simply put a screw through the dash and put a ring terminal on the end of it. make sure you have a ground and then see about that radio working....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #9 of 25 Old 04-10-2007, 07:23 PM Thread Starter
joe's_yj
joe's_yj's Avatar
ok so i should extend the wires and ground them to the frame? Thanks for your help
joe's_yj is offline
post #10 of 25 Old 04-10-2007, 07:49 PM
kaffeene
That black wire with the female disconnect is the ground. You can either cut the terminal off the end and splice it with your stereos ground wire or run a new ground to chasis from the radio. If you do that... run a 12 gauge wire. It's always better to have a larger ground and sand the paint around your grounding point on the chasis too.
I had a 95 and the ground was separate from the harness and had that terminal on it. I cut the terminal off and used it for grounding other accessories and ran a separate ground for the radio.
12' JKU Rubicon
kaffeene is offline
post #11 of 25 Old 04-11-2007, 05:14 AM
rustywrangler
You don't need to extend it to the frame. You can just ground it to the dash frame right under the radio. As said above just cut that terminal off and put a ring on it then bolt it to the dash.
post #12 of 25 Old 04-11-2007, 07:11 AM Thread Starter
joe's_yj
joe's_yj's Avatar
great thanks ill give it a shot today
joe's_yj is offline
post #13 of 25 Old 04-11-2007, 09:12 AM
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
ground it to your firewall. Its easy to reach with a cordless drill. Mount it up high so you don't see it or kick it loose. It might be your contant wire. This is a wire that when you program your radio or your clock has power to it all the time. If you clock and radio stations need set every time you turn you jeep on then that is what it is. If that is the case run it to a constant hot wire. Or even to the battery. The radio should have come with a manual that tells you what wires are what. Some radio's also have an extra wire for a power antenna. Could be that. But if everything works as is and the memory of the stations works. Then forget about it. Throw some black electrical tape over the metal end and call it good.
T-o-Double-D
TrailWorthyFab is offline
post #14 of 25 Old 04-11-2007, 03:53 PM Thread Starter
joe's_yj
joe's_yj's Avatar
ok well i ran the two grounds to the firewall and tryed tyhe radio, nothing no power at all. idont know whats wrong i connected all the wires correctly. Where should i begin the trouble shooting?
joe's_yj is offline
post #15 of 25 Old 04-11-2007, 04:08 PM
rustywrangler
THis is going to sound bad but, did you disconnect the batt to start the work by chance and not reconnect it?
IVE DONE IT!!!!
You have double checked the fuses?
Do you even get a clock?
Did you try with the keys in?
new radio install - distributor noise on Radio bestos YJ Wrangler Technical Forum 8 10-03-2009 09:47 PM
Guages and Radio doesn't work after radio install HoosierDaddyTJ TJ Wrangler Technical Forum 3 04-15-2009 02:57 AM
Radio Fuse /radio not working of after fog light install? Bonesboy JK Wrangler Technical Forum 0 03-17-2009 04:38 PM
Cb Radio Install oompaloompasc3 YJ Wrangler Technical Forum 15 07-23-2008 11:44 AM
95 yj Radio install ou812 YJ Wrangler Technical Forum 17 10-26-2005 11:08 PM
