radio / audio wiring issue - JeepForum.com
post #1 of 13 Old 08-24-2013, 06:51 PM Thread Starter
chefasg
searched for this found nothing similar ... 91 wrangler y j4.0 6cyl if it matters. I have my radio in a tuffy center console / aftermarket; the radio died and while replacing it none of the wires were the color they are supposed to be; I have orange, yellow and brown and aftermarket speaker wires - I was able to determine the the power (orange) and ground (brown) and it seems the yellow is useless (maybe). The programming will not stay once the vehicle is turned off any suggestions or has anyone seen this configuration before? thanx
chefasg is offline
post #2 of 13 Old 08-24-2013, 11:07 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Welcome to the forum. Your memory needs a constant hot. Does the orange work off of the key or is it always hot? Does the yellow show 12v with the key on or off?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #3 of 13 Old 08-24-2013, 11:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There are three wires that are a larger gauge than the speaker wires. They are a constant hot, acc switched hot and a ground. It seems you've hooked up the latter two but are missing the former.
Anticanman is offline
post #4 of 13 Old 08-25-2013, 06:37 AM Thread Starter
chefasg
the only wire that I was able to get a reading on was the orange wire other discoveries were based on touching trial and error ... Anticanman, sorry if i was not clear the three wires were orange, yellow and brown and the speaker wires were stand out aftermarket speaker wire. I was hoping that I wouldn't have to backtrace all these wires ... *sigh*
chefasg is offline
post #5 of 13 Old 08-25-2013, 07:29 AM
Rproject
1987 YJ Wrangler
Yellow is typically constant 12v+ and provides station and clock memory. With the vehicle off, hook a meter to the yellow and brown. You'll likely find 12vdc.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 13 Old 08-29-2013, 10:13 AM Thread Starter
chefasg
with a volt meter I have determined that the orange wire is the constant, brown is ground and yellow is ignition memory ~ I am getting no fire to the yellow wire; where does it trace back to ??/ or where can I tie in at ??? the cigarette lighter is not an option ... easiest route without tearing open the dash please ... thanks !!!
chefasg is offline
post #7 of 13 Old 08-29-2013, 10:18 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It should go back to the fuse box below the dash. Check your fuses under there.
post #8 of 13 Old 08-29-2013, 11:01 AM Thread Starter
chefasg
the fuses are all good ~ I am thinking about doing the impossible and tearing out the dash and redoing / simplifying all wiring and replacing the crappy gauge cluster; any advice ??? I searched but could not find a thread for this ...
chefasg is offline
post #9 of 13 Old 08-29-2013, 11:32 AM
Rproject
1987 YJ Wrangler
OK, so I'm assuming the orange goes back to the battery with an I line fuse somewhere along its path. The yellow can go to the fuse box, tied with a spade connector to the Radio slot. The fuse control for this is the 20A Accessory fuse.
Rerunning the wires is jot a great challenge, there are multiple places to pass the wire to the battery for the constant and lacing the switch wire back to the fuse box just takes a bit of laying on your back across the tub to feed the wires. Be thankful you're not trying to do it in a ZJ. Lots more crap behind the dash.
1996 White ZJ
Rproject is offline
post #10 of 13 Old 08-29-2013, 12:34 PM
SeanB95YJ
the best bet would be to check the website for the manufacturer of the radio.... but USUALLY the orange is constant (fused battery), then there should be another (usually red or red with a srtipe in my experience) that goes to an ignition hot.
every aftermarket radio I've dealt with so far uses the yellow as a trigger wire to switch a power antenna or external amplifier.
try this... with the radio power off, put a multimeter on that yellow coming off the radio... I'm thinking it should be 0v. then turn the radio on, it should be ~12v
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #11 of 13 Old 08-29-2013, 05:15 PM
jsipe007
What brand of headunit?
I know kenwood and a few other manufacturers use larger diameter wire for the 12v constant supply. Check to make sure that wire goes directly to the battery. As others here states, it sounds like your wires are mixed up. There will be a constant 12v supply into the radio as well as a 12v accessory supply.
jsipe007 is offline
post #12 of 13 Old 08-29-2013, 10:53 PM
ferrolinguist
Every radio I've ever worked with used blue as the power antenna wire(or remote), red as the constant 12v and yellow as the ignition wire.
Sent from AutoGuide.com Free App
-Beau
1993 Wrangler YJ
4.5" RE/BDS Hybrid Lift
Built Not Bought
ferrolinguist is offline
post #13 of 13 Old 08-30-2013, 08:15 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
And black as the ground.
