radiators - JeepForum.com
post #1 of 3 Old 04-15-2007, 03:41 PM Thread Starter
iwishihad1
radiators
hey everybody
a friend of mine has been having a little sting of bad luck with his jeep like most of us do. they drive find for 6 months, then it all busts loose..lol
anyways he broke an axle shaft at my house a couple weeks ago, and couldn't find the intermediate shaft anywhere, so i swapped in my spare Xj shaft, well we didn't take into account the seal sizes to it leaked. we finally got a seal in it the other day. well he goes to drive home, and his radiator blows up..he gets it home, and his seal is leaking again.
so 1 problem at a time, how should we go about replacing the radiator, how much are they, and are there any he should go for that cool better
iwishihad1 is offline
post #2 of 3 Old 04-15-2007, 03:59 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
www.yahoo.com
type "wrangler radiator"
the 4,235,233 companies that come up should be able to help you out. i've found that the first results that come up are coming up first b/c they pay to be at the top of the list.... they can afford to pay b/c they sell a ton of stuff.... which usually means they have just about the lowest prices.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #3 of 3 Old 04-15-2007, 04:20 PM
pyro9862
If it's not plastic look in the yellow pages for a radiator shop. They will clean it out, pressure test it higher than your cooling system ever goes, and solder any leaks that pop up. The last one I had done cost $40.
pyro9862 is offline
radiators in your tj cragrat TJ Wrangler Technical Forum 3 01-12-2010 01:03 PM
Radiators LightningRod TJ Wrangler Technical Forum 6 02-11-2007 05:29 PM
radiators Vermilion TJ Wrangler Technical Forum 2 06-17-2006 02:54 PM
Radiators?!?!?! RabiDaWise YJ Wrangler Technical Forum 3 05-02-2006 11:22 AM
New Radiators turfman* YJ Wrangler Technical Forum 2 11-20-2002 09:06 AM
