post #1 of Old 05-01-2006, 04:16 PM Thread Starter
RabiDaWise
RabiDaWise's Avatar
Radiators?!?!?!
Does a 4.2L and a 4.0L use the same radiator?
Redneck Jeep Club Member #18
CSA Jeepers Association
'88 Wrangler Laredo, I6, Auto, 3" Body Lift, 33"x12.50" Destination MTs, Nutter'd w/ HEI, 32/36 Weber, LOTS more to come
"Ran into a chum with a bottle of rum and we wound up drinkin' all nite" Jimmy Buffet
RabiDaWise is offline
post #2 of Old 05-01-2006, 04:31 PM
kg6mti
1987 YJ Wrangler
You should be ok as long as the 4.0 radiator is from a YJ. I can't confirm that a TJ 4.0 radiator would mount in your YJ without some mods.
Good Luck!
Experience is what you get when you get what you didnít want.
kg6mti is offline
post #3 of Old 05-01-2006, 09:47 PM Thread Starter
RabiDaWise
RabiDaWise's Avatar
Does anyone know if the tubes for the rad. hoses are on the same sides?
post #4 of Old 05-02-2006, 11:22 AM
mrbigglesworth
mrbigglesworth's Avatar
they might be slightly different, but the tubes and mounting are probably the same, right now i have a radiator i took out of an old 2.5L 1992 motor in my 1990 4.2L motor and it mounted and cools the motor fine. I would take some measurements first just to be sure.
?[]|||||||[] Black 1990 YJ 4.2L 6cyl 5spd []|||||||[]
BLACK JEEP CLUB #1000
Mods:
3.5" Rough Country Lift Kit
2 inch shackle lift
JKS Telescoping front track bar
33"x13.5" Super Swampers with 15" x10" AR Wheels
Front and Rear Auto Lockers
SYE and CV shaft in rear
Motorcraft Carb Conversion
Imperial Electric Cooling Fan
Grill Guard Front Bumper
Hella Bumper Lights
Rear Towing Crossmember and Hitch
Diamond Plate Running Boards
CB Radio
mrbigglesworth is offline
radiators in your tj cragrat TJ Wrangler Technical Forum 3 01-12-2010 01:03 PM
radiators iwishihad1 YJ Wrangler Technical Forum 2 04-15-2007 04:20 PM
Radiators LightningRod TJ Wrangler Technical Forum 6 02-11-2007 05:29 PM
radiators Vermilion TJ Wrangler Technical Forum 2 06-17-2006 02:54 PM
New Radiators turfman* YJ Wrangler Technical Forum 2 11-20-2002 09:06 AM
You may not post new threads
You may not post replies
