radiator leak - JeepForum.com
post #1 of 21 Old 12-05-2013, 12:41 AM Thread Starter
white_austin
radiator leak
i have an 88 YJ and i keep seeing drips come from the base of the bottom hose connection. i just replaced both hoses and i think the is a crack in the bace of the connection to the hose. Has this happened to anyone else? is there a way to fix it?
white_austin is offline
post #2 of 21 Old 12-05-2013, 04:24 AM
Latefreight727
Sometimes they can be fixed. If you are looking for a quick/temp fix you could try J B weld. You local Advance Auto can loan you a pressure tester to pin point the leak. Don't over pressurize it! They are not terribly expensive to buy new and easy to change.
Good luck
Latefreight727 is offline
post #3 of 21 Old 12-05-2013, 06:02 AM
Louie4
"You pass butter"
Louie4's Avatar
They are harder and harder to come by these days but a radiator shop may be able to fix it if it's all metal. If it's plastic, I'd just get a new one.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 21 Old 12-05-2013, 08:27 AM
tom_sprecher
If it's the brass type get it boiled, rodded, fixed and tested at a radiator shop. It cost me all of $95. The guy at the shop said they don't see a lot of brass radiators any more and to try and hold on to it.
Tom
tom_sprecher is offline
post #5 of 21 Old 12-05-2013, 09:45 AM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Mine was $75 and I ended up with a like new brass radiator.
GET OFF MY LAWN!
Chrisnvegas is offline
post #6 of 21 Old 12-05-2013, 05:58 PM
bpounds
bpounds's Avatar
It might be cracked, but it might not. That lower hose can sometimes be trouble to get sealed. I like to use Permatex Aviation Sealant on all my coolant connections, and I double clamp when possible.
But if it is really cracked, a new radiator is always a good investment.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #7 of 21 Old 12-05-2013, 06:02 PM
jbeebe
New radiators are around 100 bucks. It won't take long to install.
91 YJ. 4.0, 4.10's, 33's, 4" springs, 3/4" booms, 1" BL, 1" MML, d30 aussie locker, hand throttle, posi-lock, full cage, bumpers/rocker guards/engine skid, winch.
jbeebe is offline
post #8 of 21 Old 12-05-2013, 06:11 PM
Chrisnvegas
INFIDEL
Why dump a quality OEM brass that costs less than a hundred bucks to have completely rebuilt in favor of a cheap substandard radiator?
Always make me wonder...
GET OFF MY LAWN!
post #9 of 21 Old 12-05-2013, 06:24 PM
jbeebe
It may not cost him <100 to have it rebuilt. Who knows.
Also, although they have their drawbacks, many modern aluminum radiators "work" better due to more advanced design and construction (even though brass as a metal transfers heat better that aluminum)
jbeebe is offline
post #10 of 21 Old 12-05-2013, 06:43 PM
Chrisnvegas
INFIDEL
I live @ 60 miles from the hottest place on the planet and regularly wheel there as well as nearby. When my OEM radiator developed a leak, I ordered a new aluminum. Not a cheapie either.
After wheeling at the dunes at the edge of Death Valley, Jeep ran hot the whole time. Changed the water pump with an expensive OEM Mopar. Still hot at the dunes. Changed the fan clutch, again OEM Mopar, nope, still got hot and I would have to sit and let it cool. Meanwhile, my original brass was still hanging around in the garage...
Finally said screw it, took it to the local shop. Was surprised to find out they only charged $75 for a rebuild. This was in May
Went back to Death Valley (Dumont Dunes) in June.
115 degrees, never exceeded 215 or so.
I guess the AMC/ Chrysler engineers got the cooling system right after all.
GET OFF MY LAWN!
post #11 of 21 Old 12-05-2013, 06:53 PM
jbeebe
Well last year I was driving my yj on the surface of the sun and the aluminum radiator was the only thing that kept it cool. But instead of coolant i used baby tears. There, now I one-upped you!
Jk man Haha. Aluminum vs brass/copper radiators have been debated for years. One man's potatoe is another man's potahtoe
jbeebe is offline
post #12 of 21 Old 12-05-2013, 06:59 PM
Chrisnvegas
INFIDEL
We were camped there too. It got down to 103 at about 2:00 am. We sat on top of a really high dune and drank a few lukewarm beers. By 11:00 am the next day it was 114. Friend of mine was riding a Raptor. The heat from the exhaust burned the inside of his leg and his leg never touched it. It was just plain hot.
I packed up the toyhauler and got the heck out. Will never go there in June again.
I know nothing about cold. Heat? Yep.
GET OFF MY LAWN!
post #13 of 21 Old 12-05-2013, 07:09 PM
RockWoRM
RockWoRM's Avatar
off topic and not to be busting your balls... but why would anyone go to Death Valley (or Dumont) in the middle of summer?
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #14 of 21 Old 12-05-2013, 07:17 PM
Chrisnvegas
INFIDEL
The Night Drags of course!
Turbo Banshees, R1 powered Raptors and it's a big party! Just not a good idea to stay the next day.
GET OFF MY LAWN!
post #15 of 21 Old 12-05-2013, 08:04 PM
baritone_mike
I had a small leak fixed in a brass radiator in my jeep 2 years ago. Last week going up a forest road I had both belts start slipping from the radiator spewing antifreeze on them. I an going to try to sell it for scrap.
My brass one has gave out on my twice. The first time I paid to have it fixed. The second time I bought a "cheap" plastic one. For $150 I have a brand new radiator that will last 10+ years, or I could drive back to the Radiator shop that fixed it last time and give them $100 to fix it again and hope it lasts another 2 years. My 1997 car had a OEM plastic radiator in it, it was still working just fine when I replaced it last year due to discoloration of the plastic, I have no issues with a Plastic/aluminum radiator.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
