Radiator Leak - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Radiator Leak
Engo winches available at www.rockridge4wd.com! Free shippThe Original 3/8" Ruffstuff Diff Cover!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-21-2011, 11:54 PM   #1
94YJ4L
Radiator Leak
I have the stock radiator on my 4.0. On hot days, or after running on trip of more than 30 miles, I can smell the antifreeze. After about a week, I have to put more antifreeze into it. I have looked all over the engine and found nothing. No water in the oil BTW.
One day, I noticed that when I run it for about 30 minutes or so, it's "leaking" at the overflow spigot on the top of the radiator. As it's stock, it has the plastic cap for the top of the radiator. Is there a way to fix this or am I destined to buy a new radiator. Doesn't seem to overheat, at least not by the temp gauge. But it does seem to get louder as it looses enough coolant.
My heater doesn't blow hot air, BTW. No water/coolant in the cab. Probably a clogged heater core.
Really at a loss. Can't use Gorrilla on it as the bottle says, "not for use on plastic".
94YJ4L is offline   Reply With Quote
Unread 07-22-2011, 12:13 AM   #2
Xpress
Try a new radiator cap first.
I had 3 problems with mine:
-Lack of thermostat
-Bad water pump
-Bad radiator cap
I fixed all of those things and it ran at operating temperature and my heater started to put out lots of heat.
[url=http://www.jeepforum.com/forum/f12/another-5-2l-yj-thread-1503048/][FONT="Arial Black"][COLOR="Lime"][SIZE="4"]My 5.2L Build thread[/SIZE][/COLOR][/FONT][/url]
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-1996 Jeep Grand Cherokar 5.2L, donor and rainy day driver
-2004 Kawasaki KLR650 sunny day driver
[QUOTE=mudsweatNgearz;21162729]Leave em off and weld an I beam on. Bumperetts just scream homo.[/QUOTE]
"A well regulated Militia, being necessary to the security of a free State, the [B][I]RIGHT[/I][/B] of the people to keep and bear Arms, [B][I]SHALL NOT BE INFRINGED[/I][/B]."
Xpress is offline   Reply With Quote
Unread 07-22-2011, 01:02 AM   #3
94YJ4L
Already tried the cap. no change...will look at the thermo and the pump. Would taking off the return line from the heater show if anything is coming out?
Unread 07-22-2011, 04:32 AM   #4
hdsport
2008 WK
More info, please
OK, so can you tell us exactly where the leak is? Is it at the interface between the plastic "cap" and the core OR is it the Radiator cap?
Advise, please.
2001 Winnebago Adventurer 32v Motor Home
2008 Jeep GC Limited Toad, 4.7 L V-8, QTII
US Army Vet, 8th Army, 11th Evac SMBL Hospital, Pusan, South Korea
In God We Trust
hdsport is offline   Reply With Quote
Unread 07-22-2011, 11:24 AM   #5
94YJ4L
Looks to be at the cap, where the overflow tube connects to the neck. Also, the resevoir is full, so it doesn't look like it's drawing from it like it should
Unread 07-22-2011, 11:36 AM   #6
jbolty
jbolty's Avatar
Pretty common for cracks to develop in thos eplastic radiators. Unless it overheats there will probably not be a leaking gusher but it will not build preassue like it should and instead of pulling coolant from the overflow it may suck air thru the crack.
If you can find and confirm the crack a new radiator is in your future. Before you swap it flush, flush and back flush a few times to get the crud out of the whole system and see if the heater core is bad. You don't want to flush with the new radiator already installed because then the gunk from the block and heater core will mess up the shiny new rad.
Personaly I would replace the waterpump, belts, hoses and thermostat all at the same time and be trouble free for years.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 07-22-2011, 11:38 AM   #7
94YJ4L
Thanks for the advice...this will go on the list of things to do, along with timing chain, clutch, slave cylinder, and possible valve job
Unread 07-22-2011, 12:00 PM   #8
jbolty
jbolty's Avatar
Might as well do the timing chain while the rad and water pump are out; your already half done.
Glad I could help.
