radiator hoses busting left and right - JeepForum.com
post #1 of 24 Old 09-29-2010, 08:18 PM Thread Starter
N1vek215
A bit ago, I had a problem where my radiator went bust. I changed it out for a used one at a junker. A day later the hose going from the heater to the engine burst. I changed that one out and now a week later, the lower radiator hose just burst. What is going on? A mechanic told me, that when I changed out the radiator I should've changed every hose out, which I now plan on doing, but damn, how could this have happened?
N1vek215 is offline
post #2 of 24 Old 09-29-2010, 08:55 PM
Louie4
"You pass butter"
Louie4's Avatar
Sounds like the hoses are just old and needed replacing anyway. Who knows they might be the ones that came on it. Over time they get pliable and lose their structural integrity.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #3 of 24 Old 09-29-2010, 09:14 PM
jsawduste
2006 YJ Wrangler
Are you really so naive to ask this question ?
jsawduste is offline
post #4 of 24 Old 09-29-2010, 09:17 PM Thread Starter
N1vek215
oh I don't know, it's just seemed a bit weird that I'd run into so many radiator problems in just a week I just want to drive my Jeep
N1vek215 is offline
post #5 of 24 Old 09-29-2010, 09:18 PM
Old4X
1990 CJ7
First, check your overflow line from your radiator to your overflow tank. If this stops up, you will blow radiators, and hoses till you get it fixed.
If it is clear, try another radiator cap. I am running a 7 PSI cap. 12 to 16 is what you usually find, but my jeep runs cool, so no need to run that much pressure.
These cooling systems can build a lot of pressure, if either the cap or the hose is not working right, there is no way to regulate the pressure.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 24 Old 09-29-2010, 09:20 PM
95wrangler4life
really? he has 58 posts, so this is a relative question for someone new.
My question is, their maybe be a decent air bubble going through his system causing extra pressure and helping with the problem. Have you had any overheating issues and when you replaced your radiator, did you burp the cooling system real good?
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #7 of 24 Old 09-29-2010, 09:37 PM
vicker
it does just sound like old hoses. just change them all including the heater hoses. change the thermostat too. if the hoses are that old and neglected chances are the thermostat is as old. put a new cap on and flush the hell out of it. prestone sells a nice flush kit that ties rite into your system and gets capt for later use. luckily you didnt damage ur engine so its not an expensive problem.
vicker is offline
post #8 of 24 Old 09-30-2010, 02:25 AM Thread Starter
N1vek215
So exactly, how do I go about flushing the system? I think that would be a great idea
N1vek215 is offline
post #9 of 24 Old 09-30-2010, 02:28 AM
95wrangler4life
they sell a kit at walmart and other auto parts places, it allows you to cut one of the lines, usually the line leading into the heater core, insert a "T" fitting that has a garden hose hookup, and allows you to flush it, the "T" fitting then stays in place for future use!
Build thread:
post #10 of 24 Old 09-30-2010, 07:05 AM
leadsled01
I had a 12 psi radiator cap that was faulty so the coolant system would build up a stupid amount of pressure and blow hoses.
leadsled01 is offline
post #11 of 24 Old 09-30-2010, 07:25 AM
Krochus
Radiator cap.
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #12 of 24 Old 09-30-2010, 11:48 AM Thread Starter
N1vek215
Thing is, when I replaced the radiator I bought a brand new cap also..... could it be faulty?
N1vek215 is offline
post #13 of 24 Old 09-30-2010, 12:03 PM
lclark2074
remember your yj is at least 15 years old so all rubber is getting old and not plyable so when they changed the radiator Disturbed the hoses they will crack and not give and leek. So do what other posters tell you change all the hoses and t-stat.
night crew 226
lclark2074 is offline
post #14 of 24 Old 09-30-2010, 12:06 PM
pasinbuy
Keep up the name calling Jawdust. Sooner or later someone is going to get sick of your name calling and opinions about others and kick you out of this Forum.
pasinbuy is offline
post #15 of 24 Old 09-30-2010, 01:38 PM
jsawduste
2006 YJ Wrangler
Pass-On-By
If you do not like how I post then put me on your ignore list.
BTW, your inaccurate in name calling "jsawduste" starts with a small "j" and ends with an "e".
This guy has spent more money in mechanic fee`s and coolant then what the hoses could of ever cost him. Even his "mechanic" told him that he should replace the hoses. Seems he replaced the radiator and cap but elected not to replace hoses. The first hose was replaced with one from a junkyard.....
Show me the common sense here ?
Now he comes whining to JF and wants a miracle cure. Waste of bandwidth.
Radiator Hoses. Help 2ACR TJ Wrangler Technical Forum 8 09-30-2010 09:01 PM
silicone radiator hoses stanware JK Wrangler Technical Forum 5 06-28-2010 06:06 PM
Radiator hoses.... GCarpJeep YJ Wrangler Technical Forum 7 01-29-2009 07:27 PM
Radiator keeps busting!! why??? MC_NickP TJ Wrangler Technical Forum 5 12-23-2008 06:07 PM
Where to find radiator hoses? sonoran_Tj TJ Wrangler Technical Forum 2 03-09-2008 03:41 PM
