it quit ! Help - JeepForum.com
post #1 of 3 Old 06-19-2001, 07:19 AM Thread Starter
Shotgun
it quit ! Help
i was driveing my Jeep 87 yj and it quit...i have power. my lights work,but my radio and everything in the dash do not work. it wont start checked all wires for shorts,and checked fuses. any clues anybody???
Shotgun is offline
post #2 of 3 Old 06-19-2001, 11:14 AM
Tonka
2015 JK Wrangler
Try replacing the starter relay there should be two small green wires running to it, a red power wire from the battery and a ton of fusible links. To get home one day with my old xj, I jumped the green wires directly to power(to kick in the starter)once it starts, remove the green wires from power. MAKE SURE ITS NOT IN GEAR! if so, you may be chasing your rig down the road or worse, be run over by it.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 3 Old 06-20-2001, 12:14 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
I agree with Tonka - check the starter & the starter seloniod. If it's shorted out it will screw up your electrical system.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
Headlights Quit montanajeepcpl YJ Wrangler Technical Forum 1 09-02-2008 08:22 PM
it just quit ! blevinsbulldog1 YJ Wrangler Technical Forum 42 01-17-2008 03:22 PM
yj quit running roadyrob YJ Wrangler Technical Forum 3 06-21-2007 12:38 PM
a/c quit please help scrappy TJ Wrangler Technical Forum 2 10-29-2005 04:38 AM
92 speedo quit buzzbomb YJ Wrangler Technical Forum 5 11-28-2003 07:10 AM
